Results 1,171 to 1,180 of 1272
12-07-2025, 06:04 PM #1171Administrator
- 7,702
generally 15atdc or less for any turbo boost. supercharger is different because the exhaust is not restricted. na cams usually play decently well with superchargers, turbos are where the headache comes in. I do have another cam spec'd if i end up swapping, be like 239/243 .600/.600 114lsa
Sent from my SM-S938U using TapatalkLTX Hoarder
12-07-2025, 07:36 PM #1172LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 213
Good info, thank you! I'm running 227/235 .565/.579 109 lsa. I have a 6psi supercharger sitting under workbench and thought about throwing it on. Thanks again
Sent from my SM-S901U using Tapatalk
The Following User Says Thank You to Brandon++S For This Post:
12-07-2025, 08:28 PM #1173Administrator
- 7,702
it'll be alright, you'll lose a little boost thats all. 6psi on a stock engine will be like 4psi on a healthy engine that breathes.
please dont judge my welds. they suck, and this Hobart 0.025 wire kept kinking ON THE ROLL. wastegate merge is mocked up. hotside is burned together less both header side vband flanges. ive learned alot so far.
12-08-2025, 01:28 AM #1174LTx Guru
- 2,359
Wow…. into the Twilight Zone. Just don’t have any of the plumbing sticking out of the hood. Keep the “sleeper” look.
😀😀😀😀😀😀😀😀😀😀😀😀😀😀SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
12-08-2025, 09:03 AM #1175
Make sure you have clearance to get a ratchet on teh crank bolt for setting valves etc.
12-08-2025, 09:21 AM #1176Administrator
- 7,702
12-08-2025, 09:24 AM #1177Administrator
- 7,702
I really wanted to keep it hidden except the intercooler. but these damn as&m headers, that #1 primary comes out real wide then goes back to the collector, I can barely fit a 3" tube thru there. I may do what @shownomercy sent me a pic of, 4" dump tube to bumper exit with a boost actuated cut out, and 3" y off of it back to the exhaust. quietish until boost
12-08-2025, 06:16 PM #1178LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 213
Better welds than I could do. It doesn't have to look pretty to be fast
12-08-2025, 06:18 PM #1179Administrator
- 7,702
a grinder and paint make me the welder I aint!
12-10-2025, 10:32 AM #1180
Dam you get alot done fast. I don't see nothing wrong with those welds, metal looks pretty melted together to me. I do gorilla welds, grinder and paint too. LOL
