Page 95 of 97 FirstFirst ... 458591929394959697 LastLast
Results 941 to 950 of 966
  1. #941
    I saw that, but I think it only pertains to the Termi X Max. The regular Termi X doesn't have a J4 connector or any of the trans ICF stuff AFAIK.
    Sent from my SM-A526U1 using Tapatalk
    Ohhh, sorry, didn't know you had a non X max.
    Edit, you should be able to feed two wire VSS straight into one of the inputs of the termy x
  2. The Following User Says Thank You to shownomercy For This Post:
  3. #942
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    Well.... it runs. Haven't driven it yet and everything is filthy. Tomorrow I will throw the wheels on and see how well it moves. Everything is pretty much buttoned up except for the rat's nest of wires in the passenger footwell.
  4. The Following 3 Users Say Thank You to Catmaigne For This Post:
  5. #943
    It looks very sanitary, nice work. How bout a running video?
    Nolan
  6. The Following 2 Users Say Thank You to JOATMON For This Post:
  7. #944
    Mike
    Conshohocken, PA
    Nolan
    I'll try to get one soon. I also have a 2step programmed to one of the inputs so I can annoy the neighborhood.
  8. The Following 3 Users Say Thank You to Catmaigne For This Post:
  9. #945
    Looks good!
    Did you just do the holley game boy tune setup?
  10. The Following 3 Users Say Thank You to shownomercy For This Post:
  11. #946
    Mike
    Conshohocken, PA
    Looks good!
    Yeah I've been running on the supercharged 24x LS base calibration. Only tweaks I've made are for my I/Os, sensor data, and firing order. Drives suprisingly well, but this lazy LS timing table needs to be dialed up, especially off idle.
  12. The Following 2 Users Say Thank You to Catmaigne For This Post:
  13. #947
    I know on the base tune my holley spit out, it worked great for idling and part throttle but the generated timing curve was piston meltingly bad.
  14. The Following 2 Users Say Thank You to shownomercy For This Post:
  15. #948
    Mike
    Conshohocken, PA
    Generated as in a base cal table, or something else? Still getting familiar with this software. I think my table should look like a rescaled version of this.
    I think I could add 5 deg across the board in the idle and cruise areas, but I need to take a closer look at it. Looks very lazy for gen 1/2 architecture. The SBC base cal uses the same table strangely.
  16. The Following 2 Users Say Thank You to Catmaigne For This Post:
  17. #949
    Mike
    Conshohocken, PA
    Here's a timing table from a really old rev of my 2bar SD tune on the stock pcm. Hard to read because the axes are flipped and the MAP is scaled. Atmospheric pressure was about 55kpa after scaling and the car would idle around 30kpa after scaling (50-55kpa irl). I'll have to dump all the info into an excel to better view the differences. bin25timing.jpg
  18. The Following User Says Thank You to Catmaigne For This Post:
  19. #950
    Mike
    Conshohocken, PA
    I did two quick and dirty comparisons of my current Holley timing map (the base cal) vs. a NA Solomon tune I paid for and my own stock pcm 2bar SD mess with the rescaling undone. They look like this:
    Solomon:
    https://docs.google.com/spreadsheets...it?usp=sharing
    Mine:
    This is only in vacuum, no racecar stuff yet. Some thoughts...
    - Thing is reaaaaally down on timing with the stock LS cal. Probably why it feels like a slug off idle and with low throttle.
    - My 2bar SD tune ran out of resolution starting at 40kPa and below which is why all of the numbers are the same down there and the peak is around 50kpa.
    - My 2bar SD tune is considerably softer in vacuum than Solomon's as I've always thought his stuff was too aggressive. My IATs were never too far off of ambient in vac and the drag of a blower venting to atmosphere isn't a crazy amount. Don't think an NA tune would be worlds apart under atmospheric pressure.
    - I unfortunately have to assume that the indexing of the EFI 24x wheel is on the money with the Opti, which it probably isn't. There's probably a few degrees of fudge in there.
    Gonna dial it up a bit and see how it goes. I also need to play with the EOIT stuff, but we'll get there.
  20. The Following 2 Users Say Thank You to Catmaigne For This Post:
