Page 2267 of 2291 FirstFirst ... 126717672167221722572263226422652266226722682269227022712277 ... LastLast
Results 22,661 to 22,670 of 22909
Thread: BACON BITES!
  1. #22661
    Uhauls are super easy. That being said, bring a jack cause once you get the car on the trailer you can't open the door to get out without raising the car a tad. IDK what tow connectors are on your 1500 but the Uhauls are a flat four pin, so make sure thats good to go. And then grab a nice hitch, they are an oddball size IIRC. Lastly, make sure you bring long pieces of wood to get the ramps setup right, otherwise you gonna drag.
  2. #22662
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Keeps the carb colder and helps with atomization going into runners. Also on boats they sometimes time to level the carb if the motor is on a angle mount etc. Used to make em out of wood, but I think their all fake stuff material wise.
    Man I understand that but this is the first time ive seen something like this. And Ive been working on marine engines since 1976
  3. #22663
    Mar 2015
    Dan Dalessandro
    1997 Camaro Z28
    Thanks for all the heads up. Appreciate it man
    Sent from my SM-G920V using Tapatalk
    14.307@98.21, 2.155 60'
  4. #22664
    May is always my bog month off... literally take nearly the wntire month off for chillin... winter to spring transition around the house as well as CRUISIN OCMD... Which if u have NEVER... it is a MUST for any car guy...
    Ive been off since Tuesday and dont return to duty till the 26th... but I will be playing detective monday trying to knock out 6 search warrants and serve them all the same day.
    No... its not like on tv where they make a call and have a warrant.
    Its a long process... followed by requiring approval from the DA to then getting it approved by the DJ... THEN SERVING all the warrants.
    Fortunately 4 of them are thru facebook so serving those wont be hard... but the other two are on a Doctors office and a hospital. Gonna be a hellacious Monday....
    Rant over.
  5. #22665
    Mar 2015
    Dan Dalessandro
    1997 Camaro Z28
    It's been raining a lot here in Michigan
    My back yard had a 2 foot pond in it yesterday. Probably should fill in the hole I dug in back..
  6. #22666
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    You Camaro guys and gals seen this ?
    http://www.vfnfiberglass.com/932001camaro.htm
  7. #22667
    Damn... if I still had a camaro.
  8. #22668
    Glastek is betttaaaa
  9. #22669
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Seems I missed the rest of the site theres more to it just saw that . Both sites have good choices . I need to buy hard parts first.
    Sent from my SM-T217S using Tapatalk
  10. #22670
    Mar 2015
    Dan Dalessandro
    1997 Camaro Z28
    I guess I'm buying my girlfriend's truck. It's a more than good price for me.
    It has the typical gm rust. I'm probably just going to undercoat the shit out of it and replace parts here and there.
