View Poll Results: Wheel hp guesses
Voters
18. You may not vote on this poll
  • Won't make it
    1 5.56%
  • High 400's
    1 5.56%
  • Low 500's
    4 22.22%
  • Above 550
    12 66.67%
Page 14 of 15 FirstFirst ... 4101112131415 LastLast
Results 131 to 140 of 149
  1. #131
    Will there be a 8.5" crank pulley on the car???? Hmmmmmm no one knows......ALL TEH BOOZTZ
    Sent from my MotoE2(4G-LTE) using Tapatalk
    Well dont change mechanical stuff up after he tuned it to be right and safe...
    OWNER/ADMIN
  2. #132
    OWNER/ADMIN
    A tune change is only an email away
  3. #133
    Okay...
    OWNER/ADMIN
  4. #134
    Dec 2014
    john
    camaro
    No, they didn't, that's my point, the whole dyno is off. As long as the tune is safe its OK, we will get numbers at dyno day
    Sounds like a cluster f.
    You can get close to boost psi with pulley calcs but you won't know until its scanned loaded on the track or road. Some setups breath better than others.
  5. The Following 2 Users Say Thank You to gmpowered For This Post:
  6. #135
    Car comes home tomorrow
    Well, this was 3 days ago... how did it go @LT1convert ? Or @SSlowBoat
    OWNER/ADMIN
  7. #136
    OWNER/ADMIN
    It's home, Marcel explained that he couldn't get the converter to lock at all, dno why, thought it had lock up. Osie stated it felt a little surgier than before until it gets into closed loop. But it feels stronger all around. Marcel again explained he knows its making more, and apologized for the dyno not showing it. It only made 6.5 psi, Afr went down to 11 most of run then towards 6500 it was 11.7. He also explained now any changes can be made email. I screwed up on the impeller math, plus now the motor is built for boost, so we lost some from stock c.I. build. That's OK, they make bigger crank pulleys. He said it's definitely in the 10's with a tire and driver mod
  8. #137
    Excellent. Well less than 2 months till dyno day!
    OWNER/ADMIN
  9. #138
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Get that puppy pullied and see what it does!
  10. The Following 2 Users Say Thank You to Fastbird For This Post:
  11. #139
    Ordered
  12. The Following 2 Users Say Thank You to Ltconvert For This Post:
  13. #140
    Apr 2011
    KYLE
    95 MQBM Z28
    davison michigan
    So what do i win for voting wont make it
