Page 43 of 128 FirstFirst ... 333940414243444546475393 ... LastLast
Results 421 to 430 of 1277
  1. #421
    LTX AUTOX GURU!
    Oct 2010
    Manhattan, KS
    Thanks. I wouldn't have told you if the dfi was at fault anyways :p
    ^ this guy offered to help pay for any repair needed to the dfi, even though he never ran it. :thumbup:
    LOL.... Fair enough
    I was just doing the right thing.
    94 Trans am. Built 383/T56(437/409) Wilwoods, tubular suspension, QA1/BMR, Watts Link. Stripped down and set to kill!
    Twin Tubo build underway. !GOING AFTER LTX STANDING MILE RECORD!
  2. #422
    Im confused on ur question about air... If u blew off any coupling...wouldnt u go FAT rather than lean? I mean it would be between the blower and the TB where ever it would be...and that would kill boost...and no matter how much air the tb pulls from fresh air... It would not be as much as boosted air.... or am i misunderstanding
    Co-Owner/Admin @ LTXtech.com
  3. #423
    The FABRICATOR!
    southern illinois
    No you're right. I was just thinking that after you lift off the throttle the ecm might command an idle cell in the fuel map and go lean, based off its thinking that little to no air is coming in. But in the end, the map sensor should save you there.
  4. The Following User Says Thank You to firebird_1995 For This Post:
  5. #424
    I agree...and im assuming ur gonna run an AF guage which will be immediate tell tale once u feel power loss...and u WILL feel it...
  6. #425
    The FABRICATOR!
    southern illinois
    Yea. Maybe its not as bad as I think after all.
  7. #426
    I do understand ur concern!!!
    Btw... What are u gonna do with the hole in the hood?
  8. #427
    The FABRICATOR!
    southern illinois
    This guy right here...
    http://www.summitracing.com/parts/sum-470450
    Unless I can find a good used cowl hood on craigslist.
  9. The Following User Says Thank You to firebird_1995 For This Post:
  10. #428
    Will that cover it amd remain centered or no?
  11. #429
    The FABRICATOR!
    southern illinois
    Yep. I looked at going with a small, off centered hump (think 80's turbo trans am) just big enough to cover it but I though it wouldn't look right.
  12. #430
    LTXTech Sponsor
    Feb 2009
    Brad
    1979 Monte Carlo
    Moscow Mills, MO
    Blog Entries
    1
    Sounds like your close enough to start thinking about getting in some track time
    2013 King of Street & ES/PA Champ
    1979 Chevy Monte Carlo 383,Stock Ported Heads, 4L80 with Edge converter, QP 9", Nitrous Outlet Plate Kit
    Certified Performance & Auto Repair Inc.
