Results 1 to 4 of 4
    Default Is there a SA rocker with 7/16 stud?
    I have been searching for a SA full roller rocker that use a 7/16 stud but havent find any yet, does anyone know if there is one?
    Kristoffer
    1995 Formula M6 - LPE211/219 - GMMG - Full suspension - Full boltons
    I can't find any.
    I suppose I should ask why you would want such a thing?
    Generally if you're building something big enough to need 7/16 studs, you're
    also probably too radical for SA rockers. Although I could see that someone who already
    had 7/16 studs in a set of heads may want to try to avoid replacing them with 3/8 for a new (less aggressive) build.
    1997 Camaro SS
    Overland Park, Kansas
    Quote Originally Posted by James Montigny View Post
    I can't find any.
    -Eric
    1997 Camaro SS # 2703 - Full exhaust, brand new suspension, bolt-ons, etc.
    2004 Silverado
    Z71 - Airraid, Corvette Servo, 33" AT's, leveled, etc.
    Its kind of like that. That setup is not for me, just trying to help someone out that dont want to run NSA with guideplates etc. but want the strength of 7/16 studs. And that build is not that aggressive and would be fine with SA rockers.
    I got nsa promags 7/16 studs and plan to keep em
    Kristoffer
