Results 31 to 40 of 54
03-30-2026, 04:21 PM #31Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,648
Oh FYI, whenever the fuel gauge read 1/4 tank, it was nearly empty. I recall that being common on fbodys but not sure if there was a fix for it like recalibrating the gauge.
03-30-2026, 04:22 PM #32Administrator
- 7,693
04-01-2026, 01:21 AM #33LTx Guru
- 2,359
Shoebox wrote this up almost 30 years ago. His estimate of how much is still in the tank for each gauge mark agrees closely with the results I figured out the first year I owned my 94. As he notes, it’s all due to the somewhat triangular shape of the tank. You just learn to live with it.
http://shbox.com/1/4th_gen_tech2.html#fuel_gaugeSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
04-01-2026, 06:14 AM #34Administrator
- 7,693
04-06-2026, 09:23 AM #35
I adjusted(bent) the arm on my float when I upgraded my fuel pump. So it didn't really help anything, it's about the same, half tank and falling on the gauge is time to get gas.
04-06-2026, 09:30 AM #36Administrator
- 7,693
got the torque arm installed and driveshaft installed, that was a fight, i planned on working on it more saturday and start installing the engine harness, but by the time i got done messing with the bird and cleaning up the garage, it got windy and COOOOLD quick saturday afternoon. I fought with the torque arm long enough that when i got done with it it was dark, and it rained yesterday, so meh.
slow progress is better than no progress tho
Sent from my SM-S938U using TapatalkLast edited by SSlowBoat; 04-06-2026 at 09:58 AM.
04-06-2026, 10:10 AM #37Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,648
Unfortunately the LS driveshaft I had is one of the parts that went "missing". If you intend to stick with the stock one, you may want to get it checked/re-balanced if possible.
04-06-2026, 10:31 AM #38Administrator
- 7,693
04-13-2026, 09:23 AM #39Administrator
- 7,693
got some progress, actually got damn close to firing it off yesterday, but didnt realize there was no plug in the canton 1/2npt temp sensor hole on passenger side. filled with oil and suddenly hear oil running on the ground at 1030pm. I didnt have a plug, so threw a pan under it and cleaned up.
downpipe hits steering shaft rag eliminator, thats gonna require some tweaking.
94 harness/pcm are in as well. since im just firing it off i put the stock 93 fuel rails back on for now.
just realized I didnt take any pics after putting harness in, which is good, because it's a little messy lol
Sent from my SM-S938U using TapatalkLTX Hoarder
04-14-2026, 02:56 PM #40Administrator
- 7,693
ITS ALIVE!!!! found a 1/2npt to 3/8npt bushing at work, cut down a allen key, put a 3/8npt hex plug in the bushing, and worked it into the pan 1/8 a turn at a time.
flashed a stock 94 camaro file in with injector constant changed, and it fired basically right up! yea there's a miss or 2, but thats minor.
new issue: clutch fork hits PP. had that same exact issue years ago on my heads cam 94 in 2017. i spoke to a few guys today and they said to shave the clutch pivot .200", that'll be fun to get out but we will get it sorted.
https://youtube.com/shorts/9tHLqdNo5...CaV9EZQOua1mN3
