Page 68 of 70 FirstFirst ... 185864656667686970 LastLast
Results 671 to 680 of 692
  1. #671
    been a rough week, got sick and didnt get much done last weekend. but throughout the week ran the line, ran the purge line, used @Injuneer og nitrous filter, Amazon bottle bracket installed, system pressure tested and purge tested with my motor bump button ran lowdoller motorsports transducer to feed nitrous pressure to holley via ac pressure sensor input.
    tomorrow finish up system via wiring to holley, adjust passenger rear shock, confirm panhard is set right
    gotta get some switches too. I like how its kind of hidden. at first glance I dont feel like you catch it. I hope spray helps this like im dreaming it will.
    hope everyone is well!
    Sent from my SM-S938U using Tapatalk
  2. The Following 2 Users Say Thank You to SSlowBoat For This Post:
  3. #672
    Pressure input thru AC random sensor, to feed a Holley.
  4. The Following User Says Thank You to shownomercy For This Post:
  5. #673
    what? it's not thru a random sensor. just removed ac pressure input from that pin on holley i/o and changed to nitrous pressure/scaled.
    car does not have ac. its how it comes pin mapped from efi connection.
    what's the problem?
  6. The Following User Says Thank You to SSlowBoat For This Post:
  7. #674
    My NOS bottle brackets would have looked good in there…… 😇
    Still gotta empty out the garage.
  8. The Following 2 Users Say Thank You to Injuneer For This Post:
  9. #675
    I need that one for the other car knocknock
  10. The Following 2 Users Say Thank You to SSlowBoat For This Post:
  11. #676
    finally remounted the seat 3x. the corbeau bracket/slider was too tall. i removed the sliders and made it fixed position, was still a bit high, i proceeded to cut the feet off and then it was TOO LOW. had to use spacers and space it back up again. got the nitrous wiring completed and tied into the holley.
    one thing that i am worried about is traction with this car. it has a long torque arm (lazy on separation) and lowering springs/koni shocks. do i disconnect the front sway bar to try to help it transfer weight? the lca's are in the bottom hole but it is only barely -1.7 degrees of angle, ie not enough (similiar issue i ran into with my car).
    may try to drill another hole lower to get more angle.
  12. The Following User Says Thank You to SSlowBoat For This Post:
  13. #677
    crunch time, less than 24hrs
  14. The Following User Says Thank You to SSlowBoat For This Post:
  15. #678
    Awesome stuff. We went to Talladega for the fall races, now I’m playing catch up all week. Thanks for sharing the videos. Can’t wait to see the drag strip runs.
    Nolan
  16. The Following User Says Thank You to JOATMON For This Post:
  17. #679
    Nolan
    went 10.54 on boost alone and went 10.16 with 100 shot....at 138. went 140mph on a pass where I sprayed it out of the hole. battled us bad today. alternator had smoke coming out of it. stopped charging. then started charging again lol.
    my car was there for moral support
    Attachment 40766Attachment 40767Attachment 40768Attachment 40769
  18. The Following User Says Thank You to SSlowBoat For This Post:
  19. #680
    Sounds like it was running good. I can’t get the attachments to open but it may be because I’m using an iPad on WiFi. Had to get a new PC because of windows 11 so I brought it to the computer man to transfer all my stuff from old to new.
    Nolan
  20. The Following User Says Thank You to JOATMON For This Post:
