Page 100 of 126 FirstFirst ... 509096979899100101102103104110 ... LastLast
Results 991 to 1,000 of 1258
  1. #991
    Cowl hood from at least 20 years ago, a GM EFI event we set up at Englishtown...... Car was pretty quick.
  2. The Following 2 Users Say Thank You to Injuneer For This Post:
  3. #992
    bingo. that's the style cowl I would run if I could find one. I cant find them still made in that style, just the bubble curved cowl from vfn
    new bolt and it's installed/loctited
    waiting on a new pressure transducer for the nitrous, the one from last year was leaking out of the plug pins.
    i also may have 2 flexible lines made for the noid to plate connections, I found dynotune nitrous is still around and can make as short as 3". I need 2 at 4.5". the hardlines are a bit of a pain in the ass.
  5. #993
    1994 Trans Am
    PA, USA
    I used to DROOL over that red cowl hood. Good luck finding one.
  6. The Following 2 Users Say Thank You to harner For This Post:
  7. #994
    Quote Originally Posted by harner View Post
    about as bad of a quest as finding a LT1 SS spoiler for my kids car
  8. The Following User Says Thank You to SSlowBoat For This Post:
  9. #995
    go figure, my purge location is the issue with the middle wiper
  11. #996
    all that just to have to pull the intake again and reseal the front china wall, after a short 7 mile drive it's pissing. damnit
    do i get redneck and finger paint it with rtv and pray? or pull it. so aggravated
  12. The Following User Says Thank You to SSlowBoat For This Post:
  13. #997
    Aug 2013
    JB
    1994 Camaro Z28 1996 Camaro SS
    Atoka,TN
    IROC Motorsports is the only place that I've seen with a factory style 96-97 SS spoiler but open your checkbook WIDE open
    Sent from my SM-S918U using Tapatalk
    Same as everybody else...350 small block, double hump heads, 3/4 cam
  14. The Following User Says Thank You to Cathead For This Post:
  15. #998
    Quote Originally Posted by Cathead View Post
    i will NEVER EVER support that thief marc delisle or az2envy
  16. The Following User Says Thank You to SSlowBoat For This Post:
  17. #999
    so it appears the right stuff rtv must have been too cold and i let it skin up too much, as it did not adhere AT ALL to the block or the intake on the front china wall. i can slide a 0.015 feeler gauge thru it, feels like it pushes thru easy, like the rtv is just laying there like a gasket not under tension.
    very very very irritated. spent all this time making it pretty and shit just to tear it back apart over something dumb. but hey atleast it sounded cool
    https://youtube.com/shorts/OXVgUPXN9...4bAVYlH7jCgi2x
  18. The Following User Says Thank You to SSlowBoat For This Post:
  19. #1000
  20. The Following 2 Users Say Thank You to shownomercy For This Post:
