Page 118 of 122 FirstFirst ... 1868108114115116117118119120121122 LastLast
Results 1,171 to 1,180 of 1214
  1. #1171
    Hey, Merry Christmas. Nice work bench. Mine are nearly the same, down both walls of the shop. If you decide to mount the vice, mount it close to the leg and double the plywood under it. Then use long 1/2" bolts all the way through with thick washers. (This is what I did to mine after a serious hammer beating session nearly broke it off the bench. Thennnn, after reinforcing the bench mount, I broke the vise in half. LOL, Harbor Freight wouldn't warranty it. I bought a beefier vise and haven't broken it YET.
    Nolan
  2. #1172
    Pile of stuff on a bench can only mean one thing
  3. The Following 4 Users Say Thank You to shownomercy For This Post:
  4. #1173
    such racekor
  5. The Following User Says Thank You to SSlowBoat For This Post:
  6. #1174
    After a rough start realizing my argon was empty, snagged a new fill at lunch today
    Then I managed to snap the bolt on my Vband, but metal hot glue gun and a old bolt made short work of that
    Much more room now, and can actually get a wrench on crank to do rockers etc. Previously compressor housing was about ten mils off balancer.
    Downside, is radiator is shoved hard up against the car and turbo is tight
    Should I just chop front off and get the RSM front end? Probably.
  7. The Following 2 Users Say Thank You to shownomercy For This Post:
  8. #1175
    yea get it, so you have tig practice to do mine
  9. The Following User Says Thank You to SSlowBoat For This Post:
  10. #1176
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    Tilt the rad forward by drilling 3 new holes in the upper rad support. It'll probably clear the hood.
  11. The Following 2 Users Say Thank You to Catmaigne For This Post:
  12. #1177
    This is with the rad hard up against upper area.
  13. The Following 2 Users Say Thank You to shownomercy For This Post:
  14. #1178
    After a lot of going back and forth with myself.. decided to cut. Will need to figure out top mounts, but bottom is mounted to lower rad support. Gotta finish up the hose roughing in then take everything out to clean up edges and weld hotside.
    Now have clearance on both sides of compressor housing
  15. The Following 3 Users Say Thank You to shownomercy For This Post:
  16. #1179
    Acquired a fancy elbow
  17. The Following 3 Users Say Thank You to shownomercy For This Post:
  18. #1180
    looks oddly familiar
  19. The Following User Says Thank You to SSlowBoat For This Post:
