Page 81 of 127 FirstFirst ... 317177787980818283848591 ... LastLast
Results 801 to 810 of 1263
  1. #801
    1994 Trans Am
    PA, USA
    ...life also has a way of getting in the way, and with 2 very active in school kids, trying to focus more on the family and spending time with them.
    I can relate to all of this. I'm not necessarily burned out from hurting stuff, but rather dealing with so-called performance shops and throwing lots of money away, just to have an underwhelming experience in the end. I have been doing more and more myself, learning lots over the years and enjoying it more. But, family life is more important no matter what. When I am in my shop, I find myself enjoying it more as a result.
    The hobby will call you back when the time is right - probably when the weather breaks.
  2. The Following 3 Users Say Thank You to harner For This Post:
  3. #802
    Turbo would be cooler.
  4. The Following 3 Users Say Thank You to shownomercy For This Post:
  5. #803
    ehhh, im not going e85 and all that twirly boi bs. unless ur fabbing me a hotside
    I just wanna be cool like @blackbirdws6
  6. The Following 3 Users Say Thank You to SSlowBoat For This Post:
  7. #804
    Buy some of those fancy turbo LT1 hotside headers off facebook
  8. The Following 2 Users Say Thank You to shownomercy For This Post:
  9. #805
    give bls his engine support back first lol
  11. #806
    not much to post about. i got the fuel system buttoned up, hopefully no leaks as i pressure tested each line individually before installing on the car. just need to hunker down and get at bolting everything back up etc.
  12. The Following 4 Users Say Thank You to SSlowBoat For This Post:
  13. #807
    i hustled really hard this weekend. its not totally back together, but it fired off and ran today! 0411 24x installed. no holley yet. too broke for it right now. will make due with what we have
    https://youtu.be/Q6U9kVmt98s?si=x8yBChn5mIo1e6Qt
  14. The Following 4 Users Say Thank You to SSlowBoat For This Post:
  15. #808
    I like the way that big solid roller hits, it's music to my ears.
    Are you using HPTuners or what to set up the 411 PCM?
    Nolan
  16. The Following 2 Users Say Thank You to JOATMON For This Post:
  17. #809
    I like the way that big solid roller hits, it music to my ears.
    Nolan
    yea hp tuners for the 0411 pcm. im all new to that software though, appears everything is airflow and virtual torque based which is annoying. lotta lotta tables in there i have no clue what they do.
  18. The Following User Says Thank You to SSlowBoat For This Post:
  19. #810
    Factory PCMs are made to pass emissions, not make power.
    Sounds good though, now do a burnout
  20. The Following 3 Users Say Thank You to shownomercy For This Post:
