Results 961 to 966 of 966
05-01-2023, 08:37 PM #961Administrator
- 7,560
Supporting Member1994 Firebird Formula 381 stroker - Carrying the torch! - 9.64 @ 139.4mph
05-10-2023, 04:45 PM #962
Why the desire to have KS work with holley? Honestly curious. Also are you talking injector end angle tuning?
05-10-2023, 06:56 PM #963Xtreme Member
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,945
Less plug reading and guessing. No idea how good the knock circuit is, but something seems better than nothing.
And yea, the end angle. I believe it is fixed in the base tune. I've been reluctant to change it because I know it's going to throw all of my low rpm fueling out the window.
Sent from my SM-A526U1 using Tapatalk96 Z28 - ERE-383, AFRs, 9", Procharger D1, TermiX, etc.
05-19-2023, 01:44 PM #964
As a data point, I swapped in 220# injectors, and updated the ECM for the new injector data. Checked learning trims, and their close to if not zero area.
Then I switched on the IEA (mainly cause I like to tinker) and have driven it for awhile now. Learning trims still show next to no areas that indicate change is needed.
Data wise, didn't seem to do much, BUT in my head, seems to have cleaned up idle and the off idle slow hits quite well. So who knows.Correlation does not imply causation.
07-24-2023, 09:23 AM #965Xtreme Member
- Mike
- Conshohocken, PA
- 1,945
Just getting around to tinkering with this thing again. A made a couple tune changes and it seems to be driving less like an old farm truck.
1. I got around to setting up the IEA table in the advanced ICF. I used the v2.6 excel that is floating around and have been experimenting with a few different inputs. Right now it is about -160° at idle and it generally hangs out between -155° and -175° during cruising. Throttle response is 1000% better than the fixed -90° from the base cals, idk who came up with that figure and the built in injector phasing calculator is trash.
2. I upped the min injector pulse width to 1.65ms. These Deka 80s seem to act all wonky starting at <1.55 and were causing lean pops on decel. Unfortunately, a side effect of this is that the pulse width hits the floor too fast during coasting and my fuel goes to 11:1. BUT...
3. I got the DFCO working properly which can be a band-aid for hitting the pw floor.
@shownomercy What were you running for IEA on the 80's? I looked around in the old tune you sent me, saw it was fixed at 0° and didn't see anything in the advanced ICF tables.96 Z28 - ERE-383, AFRs, 9", Procharger D1, TermiX, etc.
07-25-2023, 11:20 AM #966
I never had IEA setup on the 80s afaik, I only started messing with it once I tossed the 220s in.
