Results 91 to 100 of 1265
06-09-2022, 11:00 AM #91Administrator
- 7,696
fti did say it could have to do with loading since its on a 26" tire as opposed to a 28" tire. maybe friday night ill throw the 28"s on and go to island again. I was also talking to other Turbo 400 LT1 racers about it and a few think its either converter or trans related, so we will dig in.
All growing pains. learning the car and what it likes/doesnt like etc. and my automatic trans knowledge is to the extent of what frank taught me, whenever i broke something LOL so i agree with you on that. power goes in magic happens and sometimes it works in an auto lol
Sent from my SM-S908U using TapatalkLTX Hoarder
06-10-2022, 08:41 AM #92Administrator
- 7,696
Supporting MemberLast edited by SSlowBoat; 06-10-2022 at 09:52 AM.
06-10-2022, 09:59 AM #93LTx Guru
- 2,359
I just wish it was running like I told you it would.
06-10-2022, 09:59 AM #94Administrator
- 7,696
06-10-2022, 07:53 PM #95Administrator
- 7,696
The corbeau is now the passenger seat, along with the og harness. functions fine for the fiance.
This evening did a 25ish mile drive varying speed between 40-65mph and varying traffic conditions, od on and off. temp didnt exceed 210f, stayed around 195-200 ish even with a few little roll into it wots.
one thing i did notice is a shudder when you roll into it with the gear vendors od engaged. not sure if it is the gv or the converter, feels like as the converter loads up it shudders with a heavy heavy load.
i havent shifted the gv wot yet at the track, since i didnt hit the limiter and its a solid roller (all teh rpm!)
06-10-2022, 10:10 PM #96LTx Guru
- 2,359
Don't know that I ever experienced the “shudder”. Don't know that I ever tried what you did. It wasn’t driven a whole lot on the street.
A complete Gear Vendors setup comes with an electronic controller that disengages it at low RPM/MPH (or some combination thereof?). Bought the unit used from Baxter. He never used the electronic control, don't know if he even had it. We both installed it for the benefit of an extra gear on the freeway. He got rid of it to get weight down. His 97 SS tipped the scales at close to 4,000# with driver.
The fact they sold it with a controller suggested to me that maybe it wasn’t good to run it in a “lugging” situation. But it’s such a simple planetary gear set that I can¡t see it with issues. GV actually suggests it is useful to “split” gears though. It's popular in towing applications. So your 3-speed auto becomes a 5-speed + OD auto. 1 - 1/OD - 2 - 2/OD - 3 - 3/OD. Seemed unnecessary in my application.
I tested the engagement at the top end (nowhere near reaching redline) and it was seamless. Used it on the freeway, was seamless. I actually had delusions of needing it at the top end with the 4.11 gears. I calculated it was going to hit the 7,000 RPM nitrous cutoff at about 134/135 MPH (from memory - as noted, don't have access to the spreadsheet any more). I though it should top that (but not by much) with the full 300 shot.
06-10-2022, 10:22 PM #97Administrator
- 7,696
i think a wire is loose on it, sometimes after hitting a bump it feels funny engaging. i will check tomorrow. i gotta fix the speedo too. i wasnt lugging it persay, i was using it like i tune a 4l60e to go locked at 55mph-ish when just cruising, then rolling into it.
I am going to soften up the rear shocks as well, as a radial doesnt really squish too much, so i need a little more weight transfer.
08-06-2022, 01:52 PM #98Administrator
- 7,696
this was the situation for the last monthish since the trans temp fiasco when cruising more than a few miles. think i got it sorted now. removed the horizontal mounted permacool and installed a 30000 gvwr rv bar and plate like frank would tell me to use back in the day, mounted to rad directly so it always gets airflow. also installed my innovative wiring battery cables and a lt4 mini starter i had laying around as the cvr loosened and cocked sideways, causing it to chip teeth and grind. finally installed my burkhardt bumper support.
Took for a ride today, 33 miles, bunch of 3rd gear hits and a few dig hits, trans temp didnt exceed 180f. normally it wouldve been over 200 after a few 3rd gear hits while rolling, so i think we got it sorted
Sent from my SM-S908U using TapatalkLast edited by SSlowBoat; 08-11-2022 at 09:40 AM.
The Following 3 Users Say Thank You to SSlowBoat For This Post:
08-08-2022, 07:32 AM #99Xtreme Member
- Nov 2008
- PA, USA
- 2,471
Are you using those filters as cabin filters? They're a little big but probably get the job done.
Nice job with the trans cooler upgrade!
The Following User Says Thank You to harner For This Post:
08-09-2022, 09:08 PM #100Administrator
- 7,696
Supporting MemberLTX Hoarder
