Results 61 to 70 of 1258
05-18-2022, 09:25 PM #61Administrator
- 7,693
05-18-2022, 09:37 PM #62
05-18-2022, 09:45 PM #63Administrator
- 7,693
05-18-2022, 10:03 PM #64
Cool if you can buy one. I was just curious why they went obsolete. These folks might be able to help, they were real easy to work when I bought a new set of 42's. Price was very reasonable on mine. (Lucas paddle 42lb EV1)https://fuelinjectorconnection.com/collections
05-18-2022, 10:18 PM #65Administrator
- 7,693
05-18-2022, 10:23 PM #66
FWIW I "jerry-rigged" a 12volt source with a push button to do this one time. I think this is a nice $50 kit to do the same. Seems to be a decent tool and you get the injector juice.
05-18-2022, 10:31 PM #67Administrator
- 7,693
05-18-2022, 10:50 PM #68
https://www.google.com/search?q=0280...hrome&ie=UTF-8
ONE FOR $20.00 OR EIGHT FOR 129.58 EBAY
Says those part numbers are 65lb ,2.8 ohm, EV1'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
05-18-2022, 10:51 PM #69Administrator
- 7,693
05-19-2022, 07:24 AM #70
I kind of figured you had already googled them. I was curious about them being low impedance. I'm assuming they are required because of the nature of the drivers in the Motec ECM? Even at my age I'm always learning things.
