Results 61 to 70 of 176
Thread: Project Formychicken 2.Slow
10-24-2020, 06:28 PM #61Administrator
- 7,698
slowly but surely. finances are super tight right now, pilfer the scrap pile and used parts bin is in full effect.
Sent from my SM-N975U using TapatalkLTX Hoarder
10-25-2020, 10:17 AM #62
Looking good Man, clean ride. I know what you mean when you say super tight finances, I had to check up on my project until I got my credit card bill paid down some. LOL
10-25-2020, 10:25 AM #63Administrator
- 7,698
11-08-2020, 08:52 PM #64Administrator
- 7,698
got the car out today, retuned for 3.42 gears, verified all electronics working, bled brakes, etc. go to do a little drive to verify brakes worked, and whenever i touch the gas at all the balance weight on the gm aluminum driveshaft hits the driveshaft loop bad enough to give knock readings (and feel in the shifter).
AHHHH, this spohn tunnel mount torque arm sucks.
car only has hose mod. so now have to figure out how to modify driveshaft loop to clear the ds.
11-09-2020, 03:43 PM #65Administrator
- 7,698
driveshaft loop spaced with 4-3/8" nuts and it no longer hits the driveshaft. car actually hits pretty hard in first but noses over in second. seeing a voltage drop, so gonna swap the alternator and see if that helps. @MoeHorsePower gonna need one of those send it high mile bolt on tunes.
first time in the daylight since may
11-22-2020, 12:19 AM #66Administrator
- 7,698
cleaned up and painted some free but corroded wagon wheels for the front. will be running a 245/40/17 riken tire as a ghetto front runner. this plus the ss 10 spoke/et street r weighs significantly less than the zr1's that were on it.
i was gonna get the jegs 17" skinnies and m&h radial front runners but the weight isnt more than 2 lbs different than this setup, so i will run this until i can affor real light skinnies and light 15x8 drag wheels.
Trying like hell to get to the track tomorrow. hope the weather holds.
11-22-2020, 01:19 AM #67LTx Guru
- 2,359
A 245/45-17 would keep you closer to the stock 25.7” diameter. A 245/40-17 is 1” smaller.
11-22-2020, 08:16 AM #68Administrator
- 7,698
11-22-2020, 10:36 AM #69
Riken raptors ftw
11-22-2020, 12:29 PM #70Administrator
- 7,698
the og gangsta budget tires that actually handle decent lol.
first pass right lane. i guess thats ok for 197k miles with just headers tune intake tire rear suspension. i figured it would 60ft better. that was off idle. gonna try to footbrake her a little bit
