Page 102 of 112 FirstFirst ... 252929899100101102103104105106 ... LastLast
Results 1,011 to 1,020 of 1116
  1. #1011
    Aug 2013
    JB
    1994 Camaro Z28 1996 Camaro SS
    Atoka,TN
    Ingenuity and determination
    Same as everybody else...350 small block, double hump heads, 3/4 cam
  2. The Following User Says Thank You to Cathead For This Post:
  3. #1012
    Sep 2014
    Joel
    Colorado
    Will do my best man
    That would be great I appreciate it .
    Sent from my VS996 using Tapatalk
  4. #1013
    Sep 2014
    Joel
    Colorado
    This has been on your want to do list for some time for you. I so glad to see the process moving ahead towards completion in the impala. Looking forward to seeing the impala when the transplant is complete.
  5. The Following User Says Thank You to Camaro96 For This Post:
  6. #1014
    Slow and steady... day one, wiring disconnected, fluids drained, trans out, crossmember out, exhaust disconnected, header removed...20200106_121823.jpg
  7. The Following 2 Users Say Thank You to popo8 For This Post:
  8. #1015
    Sep 2014
    Joel
    Colorado
    Making great progress. Keep the updates coming
  9. #1016
    Thanks man... so excited' and yet so nervous of what am I missing' what will go wrong' etc etc...
  10. #1017
    Sep 2014
    Joel
    Colorado
    I know that feeling I'm waiting on grage time myself to get my build done. Your is a whole different animal. With procharger not making a kit yours will be one of a kind. I wouldn't be nervous you have people working on your build that helped with your previous build. Your motor has been dialed in and you have taken care of it. Having the custom procharger bracket for the impala it looks like the belt is lined up in the photos from posts you have made. Now setting the new heart beat between the frame rails sounds like there will be modification need for clearance for the procharger. With having a full frame. How the frame needs modification to allow the procharger clearance. I look at the possibly of reclocking the procharger to see if it would clear the frame with out modification. You and the guys that have and are helping you out have thought about position and what is possible to be done with the procharger to clear the frame that didnt need to happen with the Camaro.. You should be able to use the impala wiring harness. It's been awhile since I have looked at an impala accessory drive and how it different from the camaro's.
    Sorry for the rambling on @popo8.
  11. #1018
  12. The Following 2 Users Say Thank You to popo8 For This Post:
  13. #1019
    the little motor that shouldnt have ran well but did on the right. man that thing feels like one of my kids. I MISS IT.
    cant wait hot fuzz!
  14. The Following User Says Thank You to SSlowBoat For This Post:
  15. #1020
    Mark
    Altoona, PA
    Now this is awesome to see! Sorry I haven’t been on in a long time. Can’t wait to see it running.
  16. The Following 2 Users Say Thank You to 1QUICKZ28 For This Post:
