Thread: LT1 ticking
07-14-2018, 08:56 PM #1
- Jul 2018
- Kevin Groen
- 1997 Trans Am WS6
- 7
LT1 ticking
I've searched the entire internet.1997 WS6 90k miles on car. Not original engine don't know the history. I've had it 2 years and am sick of it already. Never does it cold. Only when hot and it is intermittent. No lights on. Great oil pressure. It's not plugs or wires. Cam is good just put in new GM123 lifters so that's not. it sounds the exact same as the old lifters. Pushrods are straight rockers look good not rubbing valve covers or spring keepers. Does it with the accessories belt of. Tried 10/30 oil that didn't change it. all the rockers are getting oil. Prominent on passenger side #4 cylinder with a stethoscope. Thanks for any suggestions.
07-14-2018, 09:31 PM #2
- Feb 2014
- 1995 Mystic z28
- 444
Did you remove the alternator to intake bracket?
I have similar after my cam swap and it seems to be the alternator bouncing a little.95 Mystic Z28, 17x9 FR, 17x11 RR ZR-1's, Pacesetter LT's and Y-pipe, Borla adjustable, Moroso CAI, 2800 Stall, AC Delete, and Cracked Dash/broken lid Mod.
07-14-2018, 09:38 PM #3
- Jul 2018
- Kevin Groen
- 1997 Trans Am WS6
- 7
Yep I tried that. Thanks for your suggestion. It has a new fuel pressure regulator water pump,balancer,clutch,pressure plate, pilot & throw out bearing too.
07-14-2018, 09:43 PM #4Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Exhaust leak? Pull #4 plug wire.
Sent from my SM-T217S using Tapatalk
The Following User Says Thank You to Stormyweather For This Post:
07-14-2018, 10:20 PM #5LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 213
Sounds like exhaust leak.
The Following User Says Thank You to Brandon++S For This Post:
07-15-2018, 09:12 AM #6
- Jul 2018
- Kevin Groen
- 1997 Trans Am WS6
- 7
Thanks I'll give it a try.
07-17-2018, 11:39 AM #7Long Live the Opti
07-20-2018, 10:53 AM #8Administrator
- 7,687
manifold leak at head
Sent from my SM-N950U using TapatalkLTX Hoarder
08-21-2018, 01:07 PM #9
sounds like exhaust leak either exhaust manifold has a small crack or the exhaust manifold bolt on #4 broke
96 BBB 383/T56
08-22-2018, 08:54 PM #10
- Jul 2018
- Kevin Groen
- 1997 Trans Am WS6
- 7
