06-11-2018, 08:01 AM #1VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
EFI Connection 24X wiring Harness Options
Looking at all options for a wiring harness to swap over to the EFI Connection 24X. I purchased their kit for the double row timing set with their cover. Now I need to decide on a harness.
BP Automotive has one for $750. Believe EFI’s is roughly the same.
I believe EFI Connection makes a kit where I can convert my original harness. Car is a 93 so harness is 25 years old.
I found an LS harness for 98-02 F-Body with the computer I could get for $150. But it is a 20 year old harness.
What would you guys do?
Sent from my iPhone using TapatalkStock bottom end, Impala head gaskets, Stock heads w/stage 2 port polish Comp beehive springs, Crane 1.6 RR's, Thunder Racing cam, Cloyes Billet True Roller TC, Long tubes, custom true dual 3" w/X-pipe, Ported intake with 58mm TB, 36lb injectors, PCMforless chip, Tick Performance stage 3 M6, Strange S60 4:10's True Trac 35 spline axles, MSD complete Ignition system, Summit electric water pump and a ton of other upgrades.
06-19-2018, 07:00 AM #2
BP or the 24x harness.
I repinned my old harness and am looking to replace it in the near future.Correlation does not imply causation.
06-19-2018, 08:20 AM #3Xtreme Member
- Nov 2008
- PA, USA
- 2,471
I had gone the BP Automotive route when I wanted to go 24x. Bill was a good guy to work with and has since expanded his business substantially. The quality of the harness was what I'd consider a step above OEM. It had a provision for an EMP. The only thing that I didn't like was the coil pack wiring wasn't labeled so it took a few choppy starts and troubleshooting to figure that out.
06-20-2018, 11:58 AM #4"The Rock"
06-20-2018, 12:00 PM #5Xtreme Member
- Nov 2008
- PA, USA
- 2,471
06-20-2018, 12:02 PM #6"The Rock"
06-20-2018, 06:15 PM #7VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Thanks guys. BP it will be. Guess I need to start putting some cash back.
