Results 1 to 10 of 15
11-25-2017, 03:21 PM #1
- Jan 2012
- 75
Garrett intercooler and T56 Magnum upgrades
It's time I get rid of the old Cxracing intercooler in exchange for the best there is. I want to to do a comparison in what gains it will pick up. I will change the outlet side pipe to throttle body to 4 inch now, but, leave 3 inch for inlet side just for now until I get the F1-X blower for it little later then I will run all 4 inch pipe. Should be interesting.
4 inch vs 3 inch I had bored out the 3 inch before as well.
Left. I.D.= 3.858
Right I.D.= 2.836
No comparison 3 inch pipe
Here you can see the big difference in density as well in how the bars compare. Almost double the size.
Garrett bar. = .448
Cxracing bar = .295
Garrett core. = 27 1/4 X 12 3/4 X 5 1/8
Cxracing core = 23 1/4 X 11 3/4 X 4
This cooler should be a beast!
The Following User Says Thank You to 96famaro For This Post:
11-26-2017, 01:19 AM #2
- Apr 2009
- 93 Bird
- West Wisconsin
- 126
That's a beast!
The Following User Says Thank You to The Batman For This Post:
04-23-2018, 01:10 AM #3
- Jan 2012
- 75
Had to make some pie cuts for the 4 inch pipe. It was a tight fit because the bumper but it worked out. Fitting the intercooler was a very tight fit as well but it also worked out. I'm still running A/C condenser so for all of it to fit I'm very pleased.
Decided to upgrade to the bigger Pro Race bypass valve. It's almost twice the size so it should be good once I turn things up.
T56 Magnum 1st 2:66 5th .80 6th.63 gears. Converting to a push style clutch
Scatter shield serves as multi purpose. Gives the proper amount of spacing to use the new clutch.
Had this triple disc 168 tooth flywheel custom made for me. I don't think clutch slip will be an issue for me anymore. A very nice piece.
Decided to swap to a mono throttle body while making all the new changes. Just a few more things to do before it is all ready. And then hopefully it will be ready to make some big power.
04-23-2018, 06:23 AM #4Administrator
- 7,688
04-23-2018, 06:50 AM #5"The Rock"
Lookin good man!!!
04-23-2018, 11:51 AM #6
- Apr 2009
- 93 Bird
- West Wisconsin
- 126
Love this car
05-06-2018, 01:09 AM #7
- Jan 2012
- 75
It's been a few months now. I'm ready to just drive it again lol.
Just because it's based around an LS design. Using LS7 pressure plate with the triple discs. Plus it will be easier on the starter when cranking.
Thank you sir.
Thank you!
05-06-2018, 01:37 AM #8
- Jan 2012
- 75
Master cylinder are slightly different length.
Top= LS
Bottom=LT
Drill mod on the line 1/8th bit size.
Spec 3+ put up a lot of abuse.
Aluminium fidanza flywheel
Checking clearance for pilot bushing. I didn't and can't use the extended pilot bushing.
Needed to cut some to make clearance for slave lines.
Two shims got me at .118 clearance.
Bellhousing needed to be cut for slave lines as well.
Used stock LT1 transmission crossmember. It needs to be cut up as well.
05-06-2018, 01:46 AM #9
- Jan 2012
- 75
So waiting on BMR cross tunnel torque arm relocation setup to come in. Which will be nice because I won't need to change my exhaust after all. Still need to measure to get a custom built driveshaft. And need to address the shifter, which shouldn't be a problem. Won't be long now.
05-06-2018, 01:52 AM #10
- Jan 2012
- 75
Got the bracket for the new Procharger unit I'll be using, But little more on that later. 3/4 thick plate.
