Results 1 to 10 of 21
04-10-2018, 01:15 PM #1Lurker
- Apr 2018
- 1968 Camaro
- Westminster, Maryland
- 16
New to all of this, '68 Camaro, '93 LT1 what do I do???
Hey, I'm new the the forum, I'm new to owning a 68 Camaro, and I'm new to the whole LT1 thing. I recently traded a guy my 95 custom built Dodge Cummins ( hints the screen name) for a '68 Camaro, a 1993 Pontiac Firebird, two 93 LT1 motors, harness', computers, a 700R4, and a bunch of parts. His goal was to swap the motor but never got around to it. Then it was traded to me and now I have a bunch of stuff I have limited knowledge about, but wanna make it happen.
The past few weeks I have been day and night, researching, and learning everything I possibly can about what I have. I'm into building and tinkering but don't know about this stuff in particular.. I plan on finishing the swap, but I need guidance. I've since been working on the "stand alone" harness. I found a decent write up on "LT1swap.com", but I'm at a loss with what I need to do for the "VATS" or the ECU, it currently has a Jet Chip installed but I'm not sure what that changes from factory, I also have not heard either one of these motors run, as one had a stripped oil drain plug, and the other had the oil pan punctured upon delivery to me.
I've since ordered a replacement oil pan, and began to strip the motor for a cam job. In doing this I have found 5 collapsed lifters, 2 stripped rocker arm studs. do I keep working on this engine, or start taking apart the other? I guess i'm trying to really know If i'm wasting my time and money trying to continue this project or should I regroup and take a different course of action.. any suggestions, ideas, or advice will help me greatly in this early stage of what I'm hoping to be a long lasting, fun filled adventure!
Thanks in advance,
Chris.
04-13-2018, 10:24 AM #2"The Rock"
Welcome man... sounds like u got lotsa stuff. Lets start with some pics now....
04-13-2018, 10:30 AM #3Long Live the Opti
Collapsed lifters and stripped rockers could be a sign of things to come. You may want to investigate the other motor that's there.
I may be wrong, but I believe if you get a custom tune you can completely do away with the VATS module and stuff, but the ECU itself you'll still need unless you're moving to a 24x or the like, or a standalone.
04-13-2018, 08:24 PM #4Administrator
- 7,688
04-19-2018, 03:49 PM #5Lurker
- Apr 2018
- 1968 Camaro
- 16
Thank you!, I'll get some up as soon as I figure out how.
I have read that I can have the chip re programmed to delete the vats stuff.
Thank you guys, I'm hoping with your help this will go as smoothly as possible.
04-19-2018, 04:01 PM #6Lurker
- Apr 2018
- 1968 Camaro
- 16
86a2fb6246fe79f314e667aa08b992071f3cab3a8c91a1e5cf4a2d7512491bda_1.jpg 9f492024e6bb8e367ada0be2cac8033592372774a328d575224a0ed591c4142f_1.jpg929f5c7a0b9c54b08082a0818ebaba7de9e00c2bc61d32028ba5de29f9751f89_1.jpg0a34bde5a63338b34d530ba0c5f2081ad5de385cd74de3bfe51aabc20064404e_1.jpg
My not so pretty car... sorry about the ifunny logo, cant figure how to get it from my phone to my laptop.
04-20-2018, 06:45 AM #7
You can always go carbed if you want to simplify things. GM makes an LT1 specific carb intake, or you can convert a standard sbc intake. The bolt pattern is different and there's no water passages on the LT1 intake.
https://www.summitracing.com/parts/nal-24502592'94 coupe, 10.15 at 133.65 414" LT1, 4500 stall, n/a, pump gas, mufflers, street trim
04-25-2018, 08:58 AM #8Lurker
- Apr 2018
- 1968 Camaro
- 16
it is something that I had considered, and isn't completely out of the question, as I do have two of these motors. I was thinking I could carb one, and tinker with the FI motor in spare time... would I have to do anything to the front timing cover for the old opti-spark shaft hole? and would you recommend any specific carburetor or ignition system ?
04-25-2018, 11:47 AM #9Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
Defiantly would carb it, then you will get rid off everything that makes a LT1 bad and have one bad ass motor. Then if you wanted EFI just get a Fitech unit later.
04-25-2018, 12:01 PM #10Lurker
- Apr 2018
- 1968 Camaro
- 16
