Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
  1. #31
    Sep 2010
    1995 TransAm 385
    Quote Originally Posted by Sergiodpk View Post
    Factory LT1 manifold
    Nice! What kind of timing are you running at WOT if you don't mind sharing?
    1995 TA M6 E85
    Power mods: AFR 210 Comp Eliminators, LE LT4 intake, Custom LE cam, 12.5:1 385ci, M29
    Suspension: Koni's, 600/175lb Ground Control, 36.5/21mm sway, Fays2 Watts Link, rod-ended everything, C5 brakes, etc.
  2. #32
    I think my tuner set max timing at 40 degrees
  3. #33
    Jun 2018
    Merrick
    1996 Corvette M6 LT4
    Souther California
    Nice Build. Seems like good hp numbers to the wheels even leaving some compression on the table. Loving the clean underhood.
  4. #34
    1994 Chevy Camaro z28
    IL
    Very nice! That would be a fun setup on the street.
    94' Z -383 LTx, AI TFS 215cc heads/C/I
    S60 rear
    Stepped Hedman Hustlers an a Monoblade TB
  5. #35
    The nice thing about these LT cars is you find great deals on performance parts.
    Picked up this setup for $140
    XSpower 1 3/4” step 1 7/8” headers 3” x pipe system
  6. #36
    May 2014
    Karl Ellwein
    1995 Impala SS
    Maryland, USA
    Props on the engine build and the car build and the tuning. It take the whole package for strong numbers like that and with the low octane gas it is even more amazing. Did you mention who the tuner was/is?
