Thread: Untuned
    Nov 2017
    Matthew Hammer
    97 trans am
    Default Untuned
    Can I drive my cammed lt1 with no tune to the shop
    Did you significantly increase injector size above stock? How far is the drive to the shop? Big injectors can wash down the cylinder walls and dilute the oil. The PCM can pull out 15% excess fuel using the long term fuel corrections. After that, it’s hit or miss with the short terms.
    Johnny
    1994 formula A4
    Henderson, TN
    drove my CC503 in my last car for a while with no tune, but it was on stock fuel injectors
    Nov 2017
    Matthew Hammer
    97 trans am
    I also have stock injections
    Nov 2017
    Matthew Hammer
    97 trans am
    Still stock injectors and about 60 miles
    Shouldn’t be a problem.... but the bigger the cam is, the harder it could be to drive. You could face stalling, surge, fueling gets sloppy at low RPM with high overlap, etc.. Moderate cam shouldn't be a problem.
  7. The Following 2 Users Say Thank You to Injuneer For This Post:
  8. #7
    Nov 2017
    Matthew Hammer
    97 trans am
    Cc503 cam and it drives not to bad
