Page 188 of 192 FirstFirst ... 88138178184185186187188189190191192 LastLast
Results 1,871 to 1,880 of 1918
Thread: LTx Gun Thread
  1. #1871
    https://www.cbsnews.com/news/conceal...-act-showdown/
    Bias? What bias? No bias here, no no no.
    I don't know a single state that will issue a permit without running a background check,
  2. #1872
    Mar 2015
    Dan Dalessandro
    1997 Camaro Z28
    There are quite a few states that recognize Michigan CPLs already. Great states like California and Illinois however do not.
    Doing this gon be opening a can of worms lol
    14.307@98.21, 2.155 60'
  3. #1873
    What do people use to trim out spots for guns and ammo and stuff? Also...do u trim all the way thru the foam till the gun is resting on the inside of the case and just held in place by the cut out?
    Pic is for reference...
  4. #1874
    @popo8 I trim the middle layer, so you should have a egg foam thing above and below the cutout piece. On my first case that I got for my AR setup, I traced the gun with chalk then plucked blocks out. Not the best looking but I wasn't thinking.
    For my bolt gun, I traced it again, but used my knife and slowly cut the foam. If you go slow with a sharp knife you can get it quite nice.
    I have read, but not tried, that after you cut it, you can spray with plastidip or similar to "harden" up the outlines. Personally have not had any issues that would make me wanna do that
  5. #1875
    I will have to see if there is a way to seperate the bottom part so that its cut out and still insulated. Thanku man...
  6. #1876
    Online
    I used a hotwire knife to cut my say when gun cabinet, it worked well
  7. #1877
    Feb 2014
    1995 Mystic z28
    I have a pelican and another similar to pelican. The main layer is cut into squares and about two inches deep. Under that, another layer of solid foam that's about another 2 inches. I used a plastic butter knife and cut around each gun. One case has them flat and the other has them up and down.
    I like the up and down a bit more.
    95 Mystic Z28, 17x9 FR, 17x11 RR ZR-1's, Pacesetter LT's and Y-pipe, Borla adjustable, Moroso CAI, 2800 Stall, AC Delete, and Cracked Dash/broken lid Mod.
  8. #1878
    Feb 2014
    1995 Mystic z28
    That's the other case before I finished it up. It has twonsubcompact now in the middle.
  9. #1879
    Thanks fellas... i guess i meed to see if my lower foam is layered or not. If not, ill have to see if I can figure something out... like maybe a thin carpet under the bottom foam which i can then cut all the way thru.
    My biggest issue is my case is on the floor and as stupid as it sounds... i cant get down to it... im like a very old senior.
  10. #1880
    Online
    uhm, given your circumstances at this current time, it is understandable. you need to take it easy, which i know for you is very hard lol
  11. The Following User Says Thank You to SSlowBoat For This Post:
