Results 1,251 to 1,260 of 1277
Thread: 85 Monte Carlo SS build
11-21-2016, 09:45 AM #1251VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
Look into a hipster brake. Griner is real nice but overkill.
07-31-2017, 09:24 PM #1252The FABRICATOR!
- Jul 2011
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Update:
I went with the extreme automatics billet valve body. I now have 5x more in the valve body than the entire transmission. I got an offer on the 88mm that was worth going for. I sold it and bought a borg warner s475. After I swapped it over I decided to switch back to efi, so I went with ms3 pro. Ran that for a while and sold the 355. Ended up buying ryan stouts 383 out of his fox body to run while I looked for a set of heads for my other 383. When I swapped it out I decided to buy a new converter and have it speced for the new setup. I went with a jakes billet triple disc lockup. I've been working on getting the tune right but hopefully will have it lined out before the shootout.
Since I switched from blowthrough to efi I decided to add methanol injection. I'm currently running two 625ml nozzles and thinking of adding another spraying on the inlet of the turbo. So far so good. I like the stuff. Been running 100% meth. Smells amazing. That's all for now
The Following 3 Users Say Thank You to firebird_1995 For This Post:
08-01-2017, 08:20 AM #1253"The Rock"
Damn man... been putting in that work. I wish i had ur ability.
08-01-2017, 08:55 AM #1254Administrator
- 7,582
looks awesome !!!
Sent from my SAMSUNG-SM-G935A using Tapatalk1994 Firebird Formula 381 stroker - Carrying the torch! - 9.64 @ 139.4mph
08-01-2017, 04:04 PM #1255The FABRICATOR!
- Jul 2011
- southern illinois
- 7,164
Thanks guys. I'm going to have to stick with this setup for a while. This will be the 4th shootout my car has been to and has had a different setup each year. I can't make any progress on the suspension/weight loss things I should be doing
The Following User Says Thank You to firebird_1995 For This Post:
08-02-2017, 08:11 AM #1256"The Rock"
08-02-2017, 09:19 PM #1257The FABRICATOR!
- Jul 2011
- southern illinois
- 7,164
08-03-2017, 01:27 PM #1258"The Rock"
08-19-2017, 11:49 PM #1259The FABRICATOR!
- Jul 2011
- southern illinois
- 7,164
Well I've fought opti problems for the last time. Had some issues on the dyno and decided I'd had enough. Installed a crank trigger setup and made a cam sync out of the guts of an opti. I still need to finish the wiring and eventually make a more rigid bracket to hold the crank sensor but it runs.
08-20-2017, 12:19 AM #1260"The Rock"
