Results 11 to 20 of 20
07-14-2017, 04:01 PM #11Administrator
- 7,686
just do the warning light setup with a diode or resistor. there's wiring diagrams on Google of this very subject for lt1 electric water pumps. I've only ever had one fail, a csr. I have a rusty meizure as a back up that I took off due to it looking ugly, it had 100k miles on it and worked fine
Sent from my SAMSUNG-SM-G935A using TapatalkLTX Hoarder
07-14-2017, 04:31 PM #12VIP Member
- Javier
- 1997 Trans Am WS6
- The Final Frontier.
- 737
can you guys pm me any links to wiring kits, diagrams and what not?
I have google searched but unfortunately a bunch of lower quality from other forums (also lower quality) clog up my search (I wont name names LOL)97 Trans Am WS6, LT1 factory 4bolt freak, M6,
68 Firebird 400, YC 400, 670 heads M4
14 Fiat 500e, 83kW motor, 24kWh 364 V battery
07-14-2017, 05:54 PM #13"The Rock"
07-14-2017, 07:46 PM #14Administrator
- 7,686
07-15-2017, 05:39 PM #15
OP
I have read threads about someone who came up with a "idiot light" and "buzzer"
IMHO if that is what you need fine but at that point wire one up for oil pressure also
My $.02 is your temp gauge should be sufficient....you just need to look at it. Same for oil gauge
My Meziere has over 85k mi and another post his was over 100k mi, both Meziere. Way back when I put mine in I unplugged the fuse and went for a drive. Fwy was about 2 miles away and by the time I got to the top of onramp the temp gauge was 3/4 way up..not at red. So like checking mirrors, speedo, I just look at gauges within every few miles just by my driving habit. YMMV
I have also read of CSR failures. Not saying a Meziere will never fail, it will at some point just like any WP.96 BBB 383/T56
The Following 3 Users Say Thank You to BALLSS For This Post:
07-15-2017, 08:03 PM #16Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
You know theres a check gages light that will come on when you are too hot.
At home on the sofa watching the game.
07-16-2017, 10:31 AM #17
Fair enough, but what about if you short some winding's in your rotor? Still gonna have voltage, but erratic motor operation for awhile till it blows fully open. Just was saying its easier and simpler to watch your gauges. I had a CSR die on me wayyyy back in the day and I was able to catch that fine.
(OP if you do install a EWP, make sure you use quality, properly sized wiring and get a reset able breaker versus fuse)Correlation does not imply causation.
07-16-2017, 10:37 AM #18Administrator
- 7,686
07-16-2017, 01:06 PM #19Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Use a fuse holder thats is rated for the fuse if useing a fuse. Install it close to the source. Id get one thats higher amprage and use wire larger so the fuse is the week link. Ive seen holders and wire burned or melted and the fuse still intact.no more then 7 inches from the source should the fuse be.your probably looking at 10 gage or larger bigger is better.
At home on the sofa watching the game.Last edited by Stormyweather; 07-16-2017 at 01:12 PM.
The Following User Says Thank You to Stormyweather For This Post:
07-16-2017, 01:23 PM #20Administrator
- 7,686
12 gauge is fine, just be sure to use a good aftermarket blade fuse holder and not the inline glass fuse holders they come with, @Ltconvert had his fuse holder melt in Delaware 100 miles from home. almost smoked the motor
