Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    I saw this on another forum. I think he meant 305/45-17, which is a M/T size, which their chart shows as 28.1"
    Yessir i did modify that post lol
  2. #12
    Quote Originally Posted by Brandon++S View Post
    What rear end are you guys using?
    Dana 60 3.73s
  3. #13
    Sep 2015
    Brandon++S
    1997 camaro z28
    Alabama
    Ok, I've always heard stock rear + sticky tires = broke
  4. #14
    Johnny
    1994 formula A4
    Henderson, TN
    eventually it will, ive never kept my cars long enough or had enough power to break them.
  5. #15
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Stock 3.23 here as well for now want 3.73 but the gear god hasnt granted me one yet.
    on the phone using Tapatalk
  6. #16
    1994 Chevy Camaro z28
    IL
    Anybody have pictures of the 305/45r17 mounted on wheels? How wide is that tire?
    94' Z -383 LTx, AI TFS 215cc heads/C/I
    S60 rear
    Stepped Hedman Hustlers an a Monoblade TB
  7. The Following User Says Thank You to Flyinz For This Post:
  8. #17
    305mm wide.
  9. #18
    The M/T website data sheet for the ET Street R 305/45-17 shows the measured section width, when mounted on a 10.0" wide wheel is 11.7". Tread width is 10.5". Diameter is 28.1"
  10. #19
    It will stretch ur buldge depending on what size wheel u install it on. But didnt know if u knew the actual tire size was mm of width - aspect ratio of width via percentage- diameter.
  11. #20
    Just a thought...... the section width in the specs is a "nominal" value. 305mm is 12.0", but there is a +/- in the nominal size. The classic example is say the older 315/35-17 Nitto drag radial, that looks OK (maybe a little "bulgy") on a 9.5" wide wheel vs. the same size BFG drag radial that requires a 10.5 to 11.0" wide wheel for the right fit.
    Same with the aspect ratio (%). Not a precise number. As a result, the same size tires from different companies, or even 2 different tire models from the same company, can have a slightly different outside diameter than the "calculated" value. Special tires like drag tires, off-road tires, and auto-x tires seem to have the widest variation from nominal size.
  12. The Following User Says Thank You to Injuneer For This Post:
