Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
  1. #31
    Not at all...
  2. #32
    Quote Originally Posted by MoeHorsePower View Post
    If it has sat since 16 I would run a can of 44K by BG fuel injector cleaner thru it, forget the auto parts stuff, this is what the dealers used to clean out the injection systems (im sure some use others) but at one time this was not for sale to the public, If you have dirty, clogged injectors this stuff WILL clean them out. You cannot get this at your local auto parts other than NAPA, you have to go to an auto dealer to get it..
    $16 on Amazon, I've used it before
  3. #33
    Quote Originally Posted by 76Ventura View Post
    I think I will try something like that. Is the "home base" even necessary?
    I think the "home plate" purpose is to reduce resonant noise from the air flow. The F-Body had a long plastic tube (aka the "donkey dong") that hung down about 18" in front of the engine, making the elbow almost impossible to remove and replace. Everybody took it off.... using a Pert shampoo bottle cap for a plug.
  4. #34
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    It's one of two silencers on the b-bodies and they work really well. You can barely tell if the car is on with those silencers and a stock exhaust.
    Sent from my VS986 using Tapatalk
  5. #35
    Apr 2017
    Deek
    1976 Pontiac Ventura
    Ohio, USA
    "Stock exhaust"... so I DON'T need that! My car definitely does not have that. I like my muscle cars loud. I'll try that soon sometime and post results.
    '76 Pontiac Ventura - "Eileen"
    "Come on Eileen, oh, you know what I mean..."
  6. #36
    Apr 2017
    Deek
    Ohio, USA
    Alright folks, I got another brain buster for you. My battery seems to be dis-charging overnight (when it's really cold out). I thought it was the radio draining it, so I yanked it. My alternator works just fine and I have a new battery. This is driving me nuts, I have to jump my car in the morning with a portable jump starter (thank god for them). Any ideas on where I should start? I'm half considering just having a battery cut off switch.
  7. #37
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Shorted out alt can do it. Disconnect batt and reconnect is there a spark? Disconnect alt then do it again is there a spark. What im getting at is. If the battery is fully charged, and you get a spark when you connect it something is on either a audio amp or something or a short. Ive seen alt draw power while not running and still charge. Audio amp even though the radio is off can still be on. Have the alt tested. Then if not check the next big ticket item and so on.
  8. #38
    Apr 2017
    Deek
    Ohio, USA
    Fixed the battery problem. Now, there's something up with the engine bogging down. It's fine under a little press on the gas, but any more than half throttle it sputters and backfires something awful. It bogs down hardcore. I honestly have no idea what it could be. Throttle position sensor? Getting too much fuel? Just replaced spark plugs about a week ago. I severely hope it's not the Optispark. I've heard horror stories about that...
    Update: I saw a video of a Camaro that sounds like the exact problem, and they said it was a bad fuel filter. I'll be going to Advance very soon to pick myself one of those up.
  9. #39
    Check the fuel pressure before replacing parts. At idle, and out on the road under load.
  10. #40
    Dec 2013
    SoCal
    As noted, check your Fuel Pressure. Ideally you want a gage with a hose on it so you can tape the gauge to windshield and watch it under the driving conditions the problem occurs
    If just reving the motor the gauge dives down...than yes you have a fuel pressure problem. A clogged fuel filter will cause this...but often it is a failing fuel pump.
    Some auto part stores have a "loan-a-tool program where you can rent a gauge, or buy one.
    Your FP may be fine...just need to rule it good/bad before throwing parts at the car. If you want a fuel filter is fairly cheap and "may" resolve your issue if you feel you want to try that 1st. Like any other filter on the car the fuel filter is a maintenance item
    96 BBB 383/T56
