Thread: spark plugs
    Nov 2013
    Corey
    94 Camaro z28
    new hampshire
    Default spark plugs
    what are you boosted guys running for spark plugs? have tr6's in my car now and they need to be replaced, planning on installing my turbo kit when I get some time in the next few months so will be running N/A for a little bit. when searching the popular answer that I saw were br7es's, but most of the threads are 5+ years old that I could find.
    Quote Originally Posted by hokeplaya05 View Post
    stock heads? br6ef for low boost. doesn't foul as easy. for trick flows I forget but can find out tomorrow
    Nov 2013
    Corey
    94 Camaro z28
    new hampshire
    cool yeah stock mildly ported heads for now. okay to keep the gap how they come?
    TR6s here, I am flirting with how much you can run on them timing wise. But they don't foul as bad as the next step colder and their cheap.
    .025-.030 gap here with stock ported castings, low timing and about 15psi
    I would toss TR6s in, do some mild pulls and read the straps. They will tell you if you need to switch.
  5. The Following User Says Thank You to shownomercy For This Post:
  6. #5
    Nov 2013
    Corey
    94 Camaro z28
    new hampshire
    okay, so I think I will stick with the tr6's then and see what they look like after some run time. thanks guys
  7. #6
    Not run time, dyno pull time. Run time will erase the timing mark on the strap that you need to watch.
  8. #7
    Nov 2013
    Corey
    94 Camaro z28
    new hampshire
    oh okay, that isn't necessary until I add boost though right? don't have time/resources to get the car on a dyno at the moment for that. just trying to get it back on the road after sitting all winter in storage
  9. #8
    Oh yea, NA is not that temperamental
  10. #9
    you haven't worked on my car
  11. #10
    Nov 2013
    Corey
    94 Camaro z28
    new hampshire
    lol
    tr6's should be here today along with some other stuff I ordered for the car so we'll see how it runs with some fresh plugs
