Page 7 of 7 FirstFirst ... 34567
Results 61 to 70 of 70
  1. #61
    Sep 2015
    Brandon++S
    1997 camaro z28
    Alabama
    I think that u bolt stiffens everything up.
  2. #62
    Quote Originally Posted by Brandon++S View Post
    doesn't look like it, it doesn't grab anything on the master or body to support it. just acts as a stud holder basically from everything I'm looking at
  3. #63
    Sep 2015
    Brandon++S
    1997 camaro z28
    Alabama
    That old one you pulled was metal I believe, if you ordered a factory replacement the tabs are plastic. That's what I meant by stiffens it up. I think the plastic will flex more, just my thoughts when I did mine.
  4. #64
    they make fender washers for that very reason
  5. #65
    Mark
    Altoona, PA
    Default T56 Fork suddenly hitting and clutch slipping
    I don't see it supporting much. IMO.
    I would just bolt it on with washers. Your pushing a plunger not the Housing.
  6. The Following User Says Thank You to 1QUICKZ28 For This Post:
  7. #66
    Quote Originally Posted by 1QUICKZ28 View Post
    yeah that pic really puts it in perspective thanks man, couple washers and hardened bolts sounds good
  8. #67
    Mark
    Altoona, PA
    No problem. Just happened to be working on the kids car last night and snapped a pic for you. Hope you get it all worked out.
  9. #68
    Mar 2009
    Spring, TX
    The only reason they use a u-bolt is so that someone doesn't have to hold a wrench on the other side, you can bolt it up yourself. I've used regular bolts on a stock MC, and both versions of the McLeod MC (the newer one has screw-in studs and nuts) with no issues. I do not have to remove the steering shaft, but it does take some careful angling/finagling to get it around my headers.
  10. The Following User Says Thank You to Spartan7 For This Post:
  11. #69
    May 2013
    6 speed Impy
    1991 Z-28, 355, HSR, M6--2005 CTS-V (SOLD)--1994 Impala SS 6 Speed Swap--Have all blocks covered.
    Dover De
    After some research I guess anything is possible.
    Sent from my iPad using Tapatalk
    Been there done that, had that happen in my Impy in the middle of Dover, nursed it home, only had to bump start it twice.
  12. The Following User Says Thank You to 6 speed impy For This Post:
  13. #70
    Quote Originally Posted by Spartan7 View Post
    yeah it was fun sliding it around the harness/shaft and headers last night getting the old one out. thanks man
