Page 47 of 70 FirstFirst ... 3743444546474849505157 ... LastLast
Results 461 to 470 of 692
  1. #461
    Ok so this is fucked up, changed fuel pump relay, car runs for 10 seconds and dies. Did it twice. Then relay doesn't prime fuel pump. Put old relay back in siddenly works then acts up again. Vats light ok, no vats issue that I can see, unless theft deterrent module is fucking up or pcm is screwing up
    U said no vats issue... but did u disable it in the tune anyways?
    OWNER/ADMIN
  2. #462
    OWNER/ADMIN
    Yes it's disabled in tune
  3. #463
    Ok
    OWNER/ADMIN
  4. #464
    Got home from the central pa parts run and turned the key twice. Both times it primed.....i am lost lol
    I did reflash the pcm to see if that would clear it up, as a failing checksum or something could cause weird issues, and we kept jumping this car with a battery charger when the optima died
  5. #465
    Primed, but did it fire and stay runnin?
    OWNER/ADMIN
  6. #466
    OWNER/ADMIN
    Osies mom would've shot us if we started it when we got home. Will find out tomorrow. Earlier after flashing it I had restarted it 4 times and drove it a little bit. It didn't die. We will see tomorrow
  7. #467
    OWNER/ADMIN
    Before when it did the die thing after 10-20 seconds it wouldn't even click the fuel pump relay and prime
  8. #468
    Put a fuel pressure guage on it, in case it stalls again to see if it bleeds off and dies... or if it just stops running suddenly.
    OWNER/ADMIN
  9. #469
    OWNER/ADMIN
    It just stops running suddenly and the fuel pump relay under dash is not signaled from computer
  10. #470
    Ok
    OWNER/ADMIN
