Page 42 of 70 FirstFirst ... 3238394041424344454652 ... LastLast
Results 411 to 420 of 692
  1. #411
    LE ported trickflow 21 degree
    What size are they? Like... my eliminators are 227s for example.
    OWNER/ADMIN
  2. #412
    OWNER/ADMIN
    Believe they come out around 212. Didn't want to go afr, shaft mount rockers etc. They flow over 300cfm intake.
  3. #413
    Yeah... the shaft mounts are a fortune. I get it. Lol.
    OWNER/ADMIN
  4. #414
    OWNER/ADMIN
    Yeah that makes it overkill for this
  5. #415
    Lol... its never overkill. Eventually he will out grow the p600.
    OWNER/ADMIN
  6. #416
    OWNER/ADMIN
    These are the same heads and cam that Brian is running, they should be enough
  7. #417
    Gotcha...
    OWNER/ADMIN
  8. #418
  9. #419
    Well heads are on, guide plates look like they will work. Needs longer pushrods, atleast a 7.250 or a 7.3, gotta check again Tuesday when I get back over there
  10. #420
    Fucking ugh. Fought us tooth and nail all day. This is the 8th time the intake is bolted down. Had to egg out the bolt holes to line up a little bit. Bolted it down for a gasket impression to check seal as per @Fastbird. Pacesetters went in with one ding to a primary on passenger side, no other issues. Rockers and pushrods in and lashed to 3/4 per ellwein. Back at it tomorrow. Hoping to finish it up then we can bring mine in garage for yankage of engine.
  11. The Following 3 Users Say Thank You to SSlowBoat For This Post:
