    Jan 2016
    Tyler
    1995 Camaro Z28 LTX
    Default Fuel Relocation Third Line Question
    I'm doing a braided speed Inc fuel relocation through fender & I'm just curious about the third line that was wrapped in with fuel lines , Does this line also need to be ran through the fender well ? I believe it's evap? Or do you just plug it from under the car ?
    If you're deleting EVAP, but keeping the canister in place and connected, just plug the end of the metal pipe that the nyylon EVAP line connects to behind the rocker panel.
    Jan 2016
    Tyler
    1995 Camaro Z28 LTX
    Right on thank you just wanted to make sure I'm doing it correctly
    Mar 2009
    Spring, TX
    I kept EVAP on mine. I drilled a smaller third hole, used the stock plastic line, and just used some fuel line hose to extend it behind the intake to the purge solenoid.
    I deleted evap and put a spectre breather filter on the line by the rear axle. Car never smelled like gas
