Thread: No spark/fuel
11-19-2016, 08:44 PM #1
- Nov 2016
- Kyle Webre
- 1996 z28
- 4
No spark/fuel
Car is a 94 camaro z28 bought as a roller. Engine, trans, and harness are from a 95 trans am. Everything worked while engine was in the trans am. Put everything into the camaro and now I am getting no spark, or fuel. I seem to not be getting power to the pcm (all grounds are good). Engine harness has both c100 and c105 connectors, but the cars body harness does not seem to have the c105 connector, as pictured. As I understand it, c105 has a wire thats involved with the ignition switch. Is this my issue? And if so, what is the easiest way to fix it? I still have the 95 trans am, should I take the body harness wires from it, and transfer to the camaro, or is there an easier way?
11-19-2016, 09:21 PM #2Administrator
- 7,697
11-19-2016, 09:27 PM #3
- Nov 2016
- Kyle Webre
- 1996 z28
- 4
I have the harness that came with the car, I assume it's the stock 94 harness. It has a few pigtails cut off but I can cut the pigtails I need off the 95 harness I suppose. Being that I'm using a 95 trans, won't I have to run an extra wire to the trans for the tcc solenoid?
11-19-2016, 09:31 PM #4
- Nov 2016
- Kyle Webre
- 1996 z28
- 4
Also, why do I have to use the 94 harness? I've had a 94 before and it had both the c100 and c105 connections?
11-19-2016, 09:38 PM #5LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
As you may have suspected, the 94 has no C105. On the 95, C105 is mostly used for the traction control, cruise control, half of the injectors power, and the ALDL communication wire. I don't see anything about power to the pcm on that connector. You probably will have to look elsewhere for that problem. You can jumper the pink wire at C105 pin B to the pink wire at C100 pin K (only used for the V6 engine) to get the rest of the injectors power. But first, make sure there is no wire at one side of C100 pin K on the engine harness.
The Following User Says Thank You to GaryDoug For This Post:
11-19-2016, 10:31 PM #6Administrator
- 7,697
11-20-2016, 02:15 PM #7
- Nov 2016
- Kyle Webre
- 1996 z28
- 4
Okay, got started on splicing the cutoff wires back into the original 94 harness. All plugs are there, except I've traced about a foot back and there are no wires in the 94 harness for the ICM..
