10-04-2016, 08:57 AM #1
Spark plug wires and vented opti conversion.
I am looking to replace plug wires over the winter. I noticed most kits included ten wires. After reading, it looks like the coil plug wire for vented and non vented optis are different. I am pretty sure I am using the same coil wire from my non vented opti. What is the difference between the two? Could this be hurting performance?
1994 Trans Am GT, stock 28k mi bottom end LE2 H/C/I , 1.6rr, LT4 KM, moroso cai, jet hot lts, hooker y-pipe, slp powerflo, 37# inj, 255 pump, built 4l60e, 2800 stall, spohn/hotchkis/qa1 suspension etc etc.
10-04-2016, 09:50 AM #2Administrator
- 7,491
Supporting Memberits different on the coil side. one gets a standard 90 spark plug end and the other has two ends like what goes into the opti. if u did a nonvented opti msd cap that does the vent conversion to it it uses the 94 style wire. this would not hurt performance
10-04-2016, 10:08 AM #3
I have an AC Delco opti, no MSD cap. The coil wire is the original 1994 wire with the 90 degree boot, it goes on OK, but it looks like vented optis have different coil wires.
10-04-2016, 10:22 AM #4
coil is different for 96 so most plug wire sets include a coil wire for 94-95 and the other for 96. use the wire for your model year
96 BBB 383/T56
10-04-2016, 11:44 AM #5
I think it's time to replace anyways. It rusted while I was doing the H/C swap (took 5 years) I cleaned it up as best I could, but it's pretty much the only thing ignition related that isn't brand new.A little unburnt fuel left on the plugs, I don't think I'm getting enough spark.
