Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    I bought a OEM fan motor today.it should be in tomorrow.Ill put it on and see what happens.
    BEAVER
  2. #12
    Quote Originally Posted by beaver50 View Post
    Not just a fan or motor, a complete dual fan with shroud assembly is what you need
  3. #13
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    I have the complete set up on my car.The driver side fan just went down.
    BEAVER
  4. #14
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    I changed out the thermostat,the water pump,new fans.IM still heating up.the radiator is moving coolant.Somebody give me some help,I have no idea whats going on????????
    BEAVER
  5. #15
    Cameron
    Dover, De
    When you changed the radiator did you change the cap...Mine had a over heating issue and ended up being just the cap not holding pressure.
    1994 Formula - 6.0, Terminator X, Billet VS7875, "Best Cam", T56, QP 9"
    Formula Build Thread
  6. #16
    Aug 2016
    Dan H
    1995 LT1 Caprice
    How do you know the radiator is "moving coolant"?
    There's either air in the system, or the radiator is plugged. Or you have a blown head gasket, but let's stick with the easy stuff...
  7. #17
    Nov 2009
    Desert, so cal
    How hot is "heating up". Many people think 210 is too hot, but it's not.
  8. #18
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    I changed the radiator cap.I can tell its moving fluid by the radiator itself and the hoses.Also all bleeder plugs has water going threw them.Its getting hot enough for the hand to get close the the red line.i shut it down before it gets there.Im going to wire my fans up straight and see what happens.
    BEAVER
  9. #19
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    Finally got it fixed.I wired the fans up straight.no problems sense.thanks for all the help everybody give me.
    BEAVER
