Results 1 to 9 of 9
Thread: Siemans Deka Injectors
08-08-2016, 09:51 AM #1
- Aug 2013
- 356
Wanting opinions on siemens deka injectors. Anybody here running them? any experiences with them good or bad. I'm looking at picking up a set and these are a pretty good price.
08-08-2016, 10:25 AM #2VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
They are a top-notch injector. I run there 63 and a half pounders in my car
08-08-2016, 12:01 PM #3Administrator
- 7,687
08-08-2016, 12:14 PM #4
- Aug 2013
- 356
Awesome thanks guys!
08-09-2016, 09:12 AM #5
- Sep 2010
- 1995 TransAm 385
- 99
I also run the 60#'s in my car on E85, just had them cleaned and flow tested about 2 months ago after about 5+ years of use and they all still flowed within spec and very minimal to no variance between them.
1995 TA M6 E85
Power mods: AFR 210 Comp Eliminators, LE LT4 intake, Custom LE cam, 12.5:1 385ci, M29
Suspension: Koni's, 600/175lb Ground Control, 36.5/21mm sway, Fays2 Watts Link, rod-ended everything, C5 brakes, etc.
08-09-2016, 09:21 AM #6
I run a set of their 80s, cheapest big stick you can run
08-09-2016, 10:16 AM #7
- Aug 2013
- 356
I'm looking at a set of 30# they are listed for an LS1 upgrade. I've been trying to find out if they are a direct replacement for the LT1 or if they will need modified. the seller hasnt responded yet.
08-09-2016, 11:47 AM #8Administrator
- 7,687
12-08-2016, 11:19 PM #9
- Sep 2015
- BUZZ LEACH
- 1997 trans am
- 51
I agree. I run the 60 psi ones and they work great. I also paid extra to have them flow matched.
