Thread: Differential
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    Default Differential
    How can you tell if you have a 2 series or 3 series differentils?
    BEAVER
    If it's an ABS-only rear, the 2 series has a narrow reluctor gear, and the 3 series has a wide reluctor gear.
    http://www.tacreationsusa.com/images...s/dsc02810.jpg
    May 2015
    fm
    94 ta gt
    I believe 3.0x gears and up are 3 series, anything below is 2 series. Also 3 series ring gear is not as thick as 2 series.
    That's (almost) all true if the car has remained unmolested since it left the factory. But after 22 years someone could have installed 3 series gears in a 2 series carrier by either using a spacer for the ring gear, or available thicker 3 series ratio ring gear that is made to fit in a 2 series carrier. The 2 series goes up to 3.08:1.
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    That is true for the 7.5 10 bolt. The 8.5 10 bolt is 2.93 and up for series 3 if I remember correctly.
    Pretty sure he's asking about a 7.5/7.625 10-bolt.
    May 2015
    fm
    94 ta gt
    Go on google and type in 7.5 2 vs 3 series and go to images, first few pics are comparision pics
    May 2015
    fm
    94 ta gt
    Injuneer, where in nj are you, live in nj also
    Quote Originally Posted by DirtyBird1139 View Post
    East Brunswick
  10. #10
    May 2015
    fm
    94 ta gt
    Millstone for me
