Results 1 to 6 of 6
Thread: timing marks
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    Default timing marks
    Some body tell me how to set my timing in a 94 lt1.I have argued with some people helping with my build.Is it dot to dot?Or is it top dot 12 oclock and bottom dot 12 oclock.Some body help me?
    BEAVER
    Dec 2013
    SoCal
    top dot 6 o'clock bottom 12 o'clock.....aka dot to dot
    96 BBB 383/T56
  3. The Following User Says Thank You to BALLSS For This Post:
  4. #3
    Jun 2013
    Beaver
    1994 camaro Z28
    KENTUCKY
    Dot to dot on shoe box site shows #6 TDC.
    BEAVER
  5. #4
    Mar 2009
    Spring, TX
    Dot to dot or both at 12 o' clock, either one works on an LT1. You can't align the opti 180 degrees out if the marks are wrong like on a SBC (unless you force it).
  6. #5
    Mar 2015
    Joe
    The dot to dot is easier for me. You can tell there perfectly aligned and not off a tooth vs the both at 12 o'clock position.
    Like noted above, unless you force the opti on by not lining up the spline or the cam pin it's gonna be in perfect timing no matter the position of the timing chain. As long as you put he chain on correctly.
  7. #6
    Nov 2013
    Guillaume
    95 Caprice & 89 RX7
    Montreal, Qc
    Quote Originally Posted by Badazz 97 TA View Post
    This.
    I prefer dot-to-dot also, for the same reason. Very easy to see if you're a tooth off.
    1989 Mazda RX7 Turbo II, 357ci LT1, AI TFS CNC heads, Garrett GTX4708R, Ford 8.8" SAS, TH400. (Current project)
    1995 Chevy Caprice, Twin turbo 357ci LT1, 9.96 @ 141.2 mph (sold)
