    Sep 2014
    Joel
    Colorado
    Default Converting to ewp from stand water pump
    I'm working to convert my 96 LT-1 from the cam driven pump to a Epw. I'm not sure if I have to modify the the timing chain cover?
    I'm also not sure what the best way is to modify the timing chain cover ?
    Google. It's amazing what you can find.
    But, in short, you can leave the timing cover and misc alone. Pull stock MWP off, knock out the impeller and gear, then plug hole. Install new EWP instead of the stock cover and bam. You are done.
    The FABRICATOR!
    southern illinois
    Yea you will need to plug the hole the original water pump drive passed through the cover. Some guys use epoxy, some have it welded.
    A Kennedy half dollar and jb weld
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Lol... ask him how he knows.
    OWNER/ADMIN
  6. The Following User Says Thank You to popo8 For This Post:
  7. #6
    OWNER/ADMIN
    Mr ellwein taught me
  8. The Following User Says Thank You to SSlowBoat For This Post:
  9. #7
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    You can leave the drive in there if you're not pulling the timing cover. However, if it's already off then hammer the drive out and plug the hole with the half dollar. It's just another seal to leak.
    For the WP housing, press the impeller/shaft/bearing out and plug with a freeze plug. I also put a little bit of JB weld on the timing cover side of the WP to make sure no leaks.
  10. The Following User Says Thank You to Catmaigne For This Post:
  11. #8
    Sep 2014
    Joel
    Colorado
    Thank you for the information. It's nice that for now I don't have to pull the timing chain cover to install the EPW. I can do it in the future build. This is my first experience with an ewp. Thank you for the information
