Results 1 to 9 of 9
Thread: Timing Cover
    Dec 2012
    Tommy N.
    Silver 1996 Camaro Z28, Green 1996 Camaro Z28
    El Paso, TX
    Default Timing Cover
    How hard is it to change a timing cover from a 96 to a 93 style?
    Mar 2015
    Joe
    1997 Pontiac Trans Am
    Removing the timing cover isnt too bad. It depends how good you are with working on 4th gens.
    You Have to remove the water pump, opti, crank hub and lower the front of the oil pan to remove the cover. It's a day worth of work in the garage with ordinary tools.
    Its just time consuming dealing with coolant and stuff plus there is a difference going between those two covers. If you wanna keep the same opti you have to find a '95 cover but then also switch over to the longer style hub from 93-95 since they didn't have the crank sensor.
    Any reason for the switch?
    jacksonville, florida
    You would have to change the cam also it uses a spline drive for the opti
    forged 383,9.6:1,280xfi, trickflow heads,edlebrock lt4 intake,moser 12 bolt w/373
    Quote Originally Posted by tleed View Post
    You would have to change the cam timing gear, not the cam itself the dowel can just be shortened
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Dec 2012
    Tommy N.
    El Paso, TX
    My cam is for a 93-94 so my opti is for that style also and ive been fighting with a oil leak and I think its because the timing cover on the 93s have the small hole for the spline drive whereas the 96 have the big hole for the hub on the opti.
    Dec 2012
    Tommy N.
    El Paso, TX
    I bought this car with the wrong cam in it and I changed the opti for the correct one that goes with the cam and I wasn't leaking until recently I changed seals still there then yesterday while I was at work my dad was screwing around with it and re changed the opti seal and no more leak so I have no idea what the hell is going on with this car
    Nov 2014
    Walter Devine
    1996 Z28 2002 Z28
    Rowletts, Kentucky
    If it has a 95-97 timing cover and a spline drive Opti you are going to have one hell of an oil leak. I doubt that is the case. But sounds like you got it figured out
    96 Z28 LT1 stroker, cage 9 inch, spray 10.24@134.58 1.54 60
    02 Z28 edge converter, LTs, lid, cam, spray 12.0@112N/A
    Dec 2012
    Tommy N.
    El Paso, TX
    well it is a 96 and has a spline drive but its not leaking right now so I have no idea whats gonna happen it wasn't leaking when I changed it to a spline drive but I don't want to change the cam but I probably will when I get some money saved for a le2 package
    Perhaps the 1st seal was damaged on install...it happens.
