Results 71 to 80 of 297
Thread: My Turbo Build
01-30-2009, 02:39 PM #71Long Live the Opti
01-30-2009, 02:43 PM #72Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,649
I don't have a 94+ intake and haven't really looked for one to be honest...
To ask you though... how would I be able to go about hooking up the aeromotive regulator to my stock rails?
I know basically how to do it with your setup and if I find a 94+ for a good price I will go with your rails. Guess I'll start looking
02-02-2009, 02:47 PM #73Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,649
New Package today
Thanks SpeedInc!
Sorry for the blurriness my camera is on the fritz
So here is my ~$1300 clutch/flywheel/master cyl
Still waiting on:
Canton Racing Oil Pickup (backordered)
Melling Intermediate Oil Pump Shaft (backordered)
TC78 (Shipped out from Turbonetics on Tuesday, I should have it tomorrow)
Still need to order:
FUEL PUMPS! lol
Maybe a wastegate
02-02-2009, 02:52 PM #74Long Live the Opti
I don't know if you could hook up the Aeromotive to your rails. I presume you could if you could find an adapter to hook up to the stock rail fittings and kind of plumb the aeromotive inbetween the lines/rails. Of course, you could just get a stock styled aeromotive if you're going that route. Fits right into the stock rails.
02-02-2009, 02:56 PM #75Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,649
02-02-2009, 02:58 PM #76Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,649
http://store.summitracing.com/partde...16+4294908198+
I found that one, but it is for 94+ rails grr
02-02-2009, 03:01 PM #77Long Live the Opti
Well, like I said, I know they make adapters and such. You're planning on running -AN lines from the pumps and ditching the stockers right?? If that's the case, run the -AN's to a y block to a single into the stock rail inlet via adapter, out with an -AN from the stock rail outlet via adapter into the Aeromotive. Should be readily doable.
02-02-2009, 03:07 PM #78Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,649
02-03-2009, 03:47 PM #79
I too heard of people getting high HP numbers and rocking the stock lines. Heard the same from people using dual Walbro pumps. I didnt want to risk it with the lines so I sumped the stock tank, ran all braided line, and installed 2 Walbro inline pumps. No feakin dice. Had to sell the basically brand new pumps, buy more fittings and braided line, and get a big single pump. I ended up with an Aeromotive Eliminator.
I guess its because of the fuel consumption requirements of FI motors. If you need 85# or bigger injectors, I wouldnt risk it with the stock lines and dual pumps. FWIW, and IIRC, the 'bolt-in' Aeromotive kit that uses stock lines and an external A1000 pump is advertised to only 700hp N/A.- Justin
Custom tuning with HpTuners and your most common standalones.
Originally Posted by WJ Birmingham
02-03-2009, 03:59 PM #80Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,649
Dual walbros will hold well over 600whp easy... my buddy ran out of fuel on a 74mm turbo with a V6 at 550whp on a single walbro. I will not do an external pump no matter what.
I don't/wont need 85# anyways, my 60#'s will work out fine. I would never run enough boost on this motor to need 85#'s or more. I'm trying to work out something with fastbird at the moment for a custom double pumper. Might end up with AN lines from front to back even though, as we have discussed, it is most definitely overkill for my setup
oh an p.s. turbo wont be here til friday... not today like it was supposed to be
