Page 32 of 70 FirstFirst ... 2228293031323334353642 ... LastLast
Results 311 to 320 of 692
  1. #311
    Apr 2011
    KYLE
    95 MQBM Z28
    davison michigan
    Where u boost guys referencing ur Hobbs switch from? @shownomercy @Fastbird @popo8 @blackbirdws6
  3. #313
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    Intake manifold. I have a vacuum block for the various things.
    17 Corvette Z06 - 11.05 @ 125
    17 GMC Sierra Denali Dmax
  4. #314
    Default 94 Z28, old mans car
    Quote Originally Posted by blackbirdws6 View Post
    Where can one find said baller item? I have the bov reference off the port below the throttle body with a decent sized hose, like 3/8 I think.
    On your mm pcv catch can, are you running it into sc inlet or intake where pcv goes stock? I'm curious
  5. #315
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    McMaster Carr gots what you need. Figure out what you want to see vacuum/boost and get the right block to do the job. SNM is the plumbing guru.
  6. #316
    I've been bugging him today but he must be doing muscle stuff or truck stuff
  7. #317
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    He is away for a few days. Off the grid I was told. Brutespeed sells a vacuum block from vibrant performance. I didn't look into it too carefully but may be what you want.
  8. The Following User Says Thank You to blackbirdws6 For This Post:
  9. #318
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
  10. #319
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    I used a fuel line fitting that fit perfectly into the brake booster hose. then the hobbs switch simply screwed into it.
  11. The Following User Says Thank You to Fastbird For This Post:
  12. #320
    @Ltconvert there ya go
