Page 18 of 70 FirstFirst ... 81415161718192021222868 ... LastLast
Results 171 to 180 of 692
  1. #171
    Pistons look damn clean
  2. #172
    Flash is deceiving
    1,3,5,7
    Last pic no flash
  3. #173
  4. #174
    No smoking gun to be found. Guess it was just blowby, possibly on the valve seals as well. Oh well. Gotta ask elliott about the valve tips and see if its normal. Cylinders still have cross hatching
  5. #175
  6. #176
    The FABRICATOR!
    southern illinois
    You'll have to pull the piston out of the bore to see for sure if a ringland is cracked.
  7. #177
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    Pistons do look pretty clean. Any marks on the bores?
    17 Corvette Z06 - 11.05 @ 125
    17 GMC Sierra Denali Dmax
  8. #178
    Quote Originally Posted by blackbirdws6 View Post
    Just some crosshatching. Will pull pistons carefully tonight. If nothing is found, I'll probably use this bottom end for the impala to speed up that process. For whatever reason it looks like the pcv catch can wasn't doing a damn thing.
  9. #179
    Nothing wrong with any of pistons, or rings, or bearings, this motor looked very good inside. It might go back together
  10. #180
    Founding Member
    Jay
    93 Ultra Z
    Delaware
    When we put that blower on my friends car we had a lot of big puffs of smoke, the tune was adjusted and fixed the problem. Now you can just get that 383 done and in the car.
