Results 11 to 18 of 18
Thread: 3 rd gear vibration???? 4L 60
12-18-2014, 05:57 AM #11Administrator
- 7,696
Auto should be closer to -1-2
12-20-2014, 12:32 AM #12
- Aug 2014
- Rob Greenwalt
- 95 TA 383 11.5 forged, AFR 195 Eliminator, Pacesetter LT, 24x conversion, 58mm TB, 23x 24x 6xx cam
- Southern Il
- 21
12-20-2014, 12:38 AM #13Administrator
- 7,696
harmonics, pinion angle, etc could all play a factor, you dont have a nice rubber bushing soaking that up now. could even be gear noise. my firebird did that, only at 70mph on the highway it would vibrate like hell, thought it was the trans,then this, then that, here all along it was the gears harmonics coming thru the trans mount. gears ended up being shot
12-20-2014, 05:52 PM #14
- Aug 2014
- Rob Greenwalt
- Southern Il
- 21
12-21-2014, 10:29 AM #15LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- 93 Camaro, 95 Impala SS, 01 Corvette, '05 Dodge Ram
- Newark, Delaware
- 619
Get the car running at a given RPM is 3rd and notice vibration. Then het it running the same RPMs on O/D. Is the vibration the same? Now try the same test using MPH and see if the vibration is the same between 3rd and O/D. Why did you have the trans out? It's very possible that you have the driveshaft 180 degrees out.
FrankGail C. Cahall
CAHALL PERFORMANCE TRANSMISSIONS
12-22-2014, 12:34 AM #16
- Aug 2014
- Rob Greenwalt
- Southern Il
- 21
12-29-2014, 12:58 AM #17
- Aug 2014
- Rob Greenwalt
- Southern Il
- 21
12-29-2014, 10:03 AM #18LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Try a stock mount. It will atleast eliminate that variable. A new vibration after poly mount install is a VERY common complaint.
FrankGail C. Cahall
