Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. #21
    Apr 2010
    josh
    97 ss camaro
    mercer,pa
    the ebay set is the lpp knockoffs I guess. I think obx they are stepped 1 3/4 to 1 7/8 just like the lpp's. it will be interesting to compare them side by side when I get around to swapping them out as they look very similar.
  2. #22
    Apr 2010
    josh
    97 ss camaro
    mercer,pa
  3. #23
    Jun 2013
    1996 Trans AM WS6
    NJ
    yeah i bet the step is hitting the shaft. Im afraid to drive it now lol. Gotta pull it off and start grinding away or modify my LS1 shaft to bolt on.
    does the ls1 shaft actually give more clearance?
    1996 Trans Am WS6 M6 - 13.679 at 102.77MPH in 1/4. (11/07) 1986 Honda VFR750 - Jet Kit, K&N, Hindle Stealth 4into1 full exhaust, -1 front sprocket. 89.3HP to the rear wheel
  4. #24
    Apr 2010
    josh
    97 ss camaro
    mercer,pa
    not 100% sure but I don't think it does in the area we are having trouble. I think it only gives more clearance by eliminating the rag joint but I have tons of room down there. looking at pictures it looks the same to me at the top were it connects to the steering shaft and that's where my ebay headers hit
  5. #25
    Jun 2013
    1996 Trans AM WS6
    NJ
    I have a local club member with a rag joint eliminator that he can give me. Might just do that, and grind down the shaft a bit.
  6. #26
    Pull the bolts out of the column to firewall junction and have some pry the knuckle over then you tighten up the bolts. It should get you to clear, otherwise BFH time to shiny headers.
  7. #27
    The FABRICATOR!
    southern illinois
    Quote Originally Posted by miller09 View Post
    VERY similar from what I've seen.....
  8. #28
    Nov 2011
    Marc
    1995 Formula
    magnolia, DE
    The steering shaft was the only issue I had with my LPP header install. Got a ls shaft and still had to grind on it. Didnt have to dent those pretty headers tho.
    1995 FORMULA M6
  9. The Following 2 Users Say Thank You to 95 blackbird For This Post:
  10. #29
    Jun 2013
    1996 Trans AM WS6
    NJ
    Quote Originally Posted by 95 blackbird View Post
    Yeah my motor mounts may be fatigued causing it to hit on the pass side. i didnt have time to do the mounts (i bought prothane ones). so hopefully one day I will.
    It is RASPY as hell. Will 1 cat be good enough to tone down the rasp? (i need a cat to look good for NJ lol)
    Also, what are good stainless band clamps? Im not sure if @LPP will give me a new clamp. The one on the drivers collector broke while tightening it (lol).
  11. #30
    Feb 2011
    jackson mi
    I went down to advanced auto and bought 3 inch stainless band clamps for 10uploadfromtaptalk1410900527203.jpg bucks
    97 firehawk m6 with a forged long rod 355 stock heads and intake soon to be upgraded to LE 21* tfs heads and a big ass cam , rpm built level 5 t56 trans s60 with 4.30 gears umi suspension walbro pump and hot wire kit and a spinning best 12.36 @ 114 crap 60 foot.
  12. The Following User Says Thank You to 97firehawk For This Post:
