07-27-2014, 02:15 PM #1
ARP Studs, AFR heads Torque spec!
IIRC, I've used three passes using Shbox's chart, setting the last pass at 90lbs. Pretty sure that's what I've done in the past ... but I can't get anyone in my local circle on the horn to be sure.
Anyone out there know what specs would be used for the ARP Studs on the LTx block, using the AFR (210) heads?
I'd love to get this done today, if possible... . (Thanks in advance to anyone that shares).
Mike96 Z LTx. 396 Forged Eagle BE, AFR195s, CR 12.5:1 Comp Ultra-Pro Mag1.6 RRs, Lt-4 Intake, 42lb FI, 58mm TB, Comp 292XFI Cam, Kook LTs, PerformaBuilt Lvl-3, SS 3600, 4" DS, Spooled Strange D-60 w/5.13s, BMR K-mem & A-arms, Hotchkis out back, Mazeire, MSD Digi-6 , Nano-N2O, 75 shot: 7.28 @ 95.7 1.6 60' - New Build: NA-SF 7.4 1.6 60' 93 Mph
07-27-2014, 05:19 PM #2Xtreme Member
- Apr 2010
- Brian DeLuca
- 1997 Trans Am WS6
- Piscataway, NJ
- 1,297
I usually go 85lb on the last pass but I don't see 90 hurting anything if using a good wrench, proper lube, etc.
17 Corvette Z06 - 11.05 @ 125
17 GMC Sierra Denali Dmax
07-27-2014, 09:11 PM #3
- 55
OVA1, if you're using the ARP Ultra-Torque Lube 80 ft-lbs is the spec. If you're using motor oil aim for 85-86 ft-lbs.
Here you go: http://arpinstructions.com/instructions/208-4303.pdf
07-27-2014, 09:48 PM #4The FABRICATOR!
- Jul 2011
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Divide the final torque by 3. That's your three stages.
07-30-2014, 04:47 PM #5
Thanks fellas! I went with 85... It out to hold 'em down.
