    Apr 2014
    Elvis Cordovi
    1995 Camaro Z28
    Default Headers, Custom Lid, Gears, Advice Needed
    So my next mods that I plan to do are LT Headers, which ones do you guys have and which ones the best? I was thinking Pacesetter. Next up, CAI , Which ones the best ones, where could i get a custom lid made (LS1 Style , like the SLP) Next, I plan to do gears, I was thinking 3.73's due to the fact that its an Automatic and I plan on leaving the car bolt ons only until I get a daily 4 cylinder and make the lt1 my weekend car since its my daily now. Once I make it my weekend car I plan on doing more major mods to it within time, im not in a hurry at all. I have posted here before and some of you know i'm a full time college student and i'm on a budget Thats why the daily car I get will be just to get me to school and back. A to B car, so i plan on spending 1500 at the most. Also do you guys know of any good shops around the Northwest GA area to install the gears because I don't want just anyone working on my car. What times should I run in the 1/8 with 3.73 gears, lid, headers? I ran 9.30 almost 9.2's with the mods listed in my signature (basically stock) my 60ft was horrible at a best of 2.20
    1995 Camaro z28, Summit racing cutout,Vx series Muffler,BMR Strut tower brace....(More to come soon!)
    Jun 2013
    Colton Waggoner
    1995 DCM Impala SS (Nightmare)
    New Palestine, IN
    If you are doing 3.73s, you might look into throwing a bigger stall/torque converter in the lineup too. The gears and stall alone will cut a good amount of time off your current one.
    1995 DCM Impala SS
    "Nightmare"
    Follow my build thread!
    http://ltxtech.com/forums/showthread...tory-and-Build
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    I have Pacesetters on my car. They're okay. Less of a gamble than eBay headers but in retrospect I should have gone with something else. Too much $ for a less than perfect fit, lack of finish, and the ORY is low as hell.
    Also, if you're going to put headers on it then you should get a good 3" exhaust to go with it. Hooker is the cheapest but I can honestly say I hate the way it sounds. My friend has one on his 95Z with LTs and it sounds like a big rig to me. I've always had the Magnaflow which I think sounds miles ahead. However, I really like the Borla but it's $$$.
    Moroso or K&N for CAI, there really isn't a power difference between the two. I grabbed a used Moroso from eBay for $60 a while back. Recharged the filter and it was good to go.
    the summit longtubes and y are the same as pacesetters but a little cheaper. personally, i have no issues with pacesetters, my car is lowered a bit and they dont hit the ground or anything, just avoid speedbumps.
    Feb 2014
    1995 Mystic z28
    Amazon has the pacesetters right now for 240. Grab those and the summit y pipe.
    95 Mystic Z28, 17x9 FR, 17x11 RR ZR-1's, Pacesetter LT's and Y-pipe, Borla adjustable, Moroso CAI, 2800 Stall, AC Delete, and Cracked Dash/broken lid Mod.
    If you are buying headers, take a look at the option for cera-metallic coating. A quality coating will minimize rust, reduce thermal cycle weld cracking, keep the heat in the primaries and not in the engine compartment, and pick up a couple HP with the improved scavenging.
    Apr 2014
    Elvis Cordovi
    1995 Camaro Z28
    Thanks for the advice guys but there is a going to be a change in my plan. I will be leaving my car how it is ,which is basically stock til I start my college career. Once I start my college career and buy me a daily I will be doing an LQ9 swap on my 95z,4l80e trans and 9" rear end, big cam,ls6 heads etc. Yes guys i know this going to be extremely expensive but once I start my career i'll be able to the build slowly and buy the parts within time, not in a hurry at all.
    pour one out for another opti left behind
