Results 11 to 17 of 17
03-21-2014, 12:06 AM #11
- Jul 2012
- SouthWest Minnesota
- 244
Here is my table for the Throttle follower IAC vs. MPH
0 2
4 4
8 8
12 10
16 10
20 10
24 10
28 10
32 10
36 10
40 10
44 10
48 10
52 10
56 10
60 10
64 10
Edit: my counts are at 40 and idles pretty good and returns to idle pretty quick alsoLast edited by bigtoyz; 03-21-2014 at 12:08 AM.
97 Comp T/A #161 out of 164 LT1 383 stroker, TPIS/AFR heads, JE pistons, 9.3cr, extreme energy comp cams 224/230, Howards billet rods 5.85, Callies dragon slayer crank, 2 bolt mains converted to 4 bolt billet, Mildon oil pump, MSD opti, 6AL, boost retard, HVC 2 blaster coil, BBk 58mm, 50lb injectors, 3200 stall. Took 600b off to help fund twin turbo.
03-21-2014, 08:23 AM #12InActive Member
- Jul 2011
- 1996 Firebird Formula
- St. Louis, MO
- 36
does this table add the iac counts at that mph or subtract or is this the actual count value at that mph?
96 Formula
03-21-2014, 08:38 AM #13LTX Master
- Aug 2013
- 1994 z28 2005 gxp
- Wentzville, MO
- 897
do you have the stock tune or the one you had before modifiing it?
i'm running an obd1 but my throttle follower iac offset is
3
4
8
12
16
20
20
20
20
20
20
20
20
20
20
20
20
this was on a large head/cam car and idled great.
03-21-2014, 08:52 AM #14InActive Member
- Jul 2011
- St. Louis, MO
- 36
do the offset tables add or subtract?
thanks for the table hints. i'm going to try some of these after work today.96 Formula
03-21-2014, 09:03 AM #15LTX Master
- Aug 2013
- 1994 z28 2005 gxp
- Wentzville, MO
- 897
i would think it would open the iac valve more with the higher number, since most cars idle high till you come to a complete stop then drop down.
but that way you would think you wouldnt get the idle to go down... but who know could be pushing it past the limit or just cant keep up, or i could be completely wrong on what it does.
but like you already figured out, make little changes at a time, and make sure you keep the old files in case something just doesnt go right with it. also good to track what you changed as well.
03-21-2014, 09:07 AM #16
Opening the blades drop the counts, closing the blades raise the counts..
03-25-2014, 08:41 AM #17LTX Master
- Aug 2013
- 1994 z28 2005 gxp
- Wentzville, MO
- 897
did you make any progress?
