Results 1 to 6 of 6
Thread: Nitrous Timing
03-01-2014, 10:08 PM #1
- Mar 2014
- Michael
- 1993 Pontiac Trans Am
- 3
Nitrous Timing
Hey guys, anyone know how much timing should be pulled for a 150 shot? i tune the car myself as well, so what AFR do you all shoot for on spray? Thanks
03-01-2014, 10:18 PM #2
I run 29 degrees on my 150. And NGK BR7EF plugs. I try to shoot for a richer afr like 11.5.
Sent from my SCH-I605 using TapatalkDustin Dillow-Tuned by Dillow's Tuning Solutions
95 Firebird Formula Cam, Bolt Ons, QP 9 Inch 3.50 Gear, Full UMI Rear Suspension, 3700lbs
7.86 at 86.20 mph 1.67 60ft, 7.16 at 99 mph 1.51 60 ft on .063 jet NX Shark Nozzle Single Fogger
03-02-2014, 07:08 AM #3InActive Member
- Jun 2010
- Frank AKA Biggriff
- 1994 Z28 6 speed
- Yorktown
- 670
I pulled 2 degrees per 50 shot
03-02-2014, 10:24 AM #4
http://members.uia.net/pkelley2/sparkplugreading.html
tune it to what the motor wants...1994 Formula, 396cid, AFR 227's, Single plane, and 2 of the big ones.
03-02-2014, 11:25 AM #5
- Mar 2014
- Michael
- 3
Okay, well i have the br7ef plugs in the car and the car was on a stock tune and spray, plugs read good on the stock tune, i figured the stock tune was conservative enough on the timing because the plugs showed up good. But since ive changed to a cam car and will be tuning it for most power N/A i will also have to pull some timing from the car on spray. I figured 2 degrees per 50 shot would be a good place to start.
03-02-2014, 01:49 PM #6
just make sure you are using fresh plugs for each WOT pull to "read"...part throttle use will make the plugs less accurate to even unusable for collecting data
