Results 1 to 10 of 16
Thread: BIG Boost LTX Engine Builders
02-10-2014, 10:57 PM #1
Maybe some of the big dogs can help here. I'm looking for a reputable engine builders good with at least 15+ lbs of boost and at least is familiar with the lt1 platform and its limitations. Hopefully is knowledgeable about newer options like e85. I'm willing to travel or ship as needed. We have good local engine builders but none I trust with this type of build. I have talked with Lloyd and he suggested Kim Barr racing engines near Dallas. Anyone heard of him? I'm out of Little Rock, AR so the closer the better.
Troy, bigcat, anyone?
Thanks
97 WS6
06 Corvette
05 GMC Sierra
02-10-2014, 11:12 PM #2"Project Storm Trooper"
- Tony
- 93 StormTrooper Z28
- Rapid City, SD
- 4,810
cant give much help since my builder stepped down but i think you are close to @noice and they may be able to give some assistance.
@Ryan Stout @ZOHAN @Fastbird @BIG CAT might have some input also (only boosted buys i can think of off the top of my head)
Official Member of $30k Club - Work in progress1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
1987 Iroc-Z - Stock Summer DD
02-10-2014, 11:39 PM #3
02-10-2014, 11:44 PM #4Long Live the Opti
Mine, Call 911's, and BlackbirdWS6's motors were all built by Fonse Performance in Erial NJ. We were all local which was convenient. HOWEVER, BlackbirdWS6 recently found some issues with his that was causing oil consumption. Mine is experiencing very close to what his was. Call 911's has been trouble free.
02-11-2014, 09:30 AM #5
The machine shop i use is no longer open to the public, there is one guy i know in Rogers that has built LT1s, he builds everything from top alcohol funny car to circle track racing.
68 Mechanical Alcohol Injected LT1.
02-11-2014, 11:14 AM #6LTx Guru
- 2,339
Not close, but Second Street Speed in Perkasie, PA has built reliable 1,000+ HP S/C LT1's. See photo below.
http://secondstreetspeed.com/SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
02-11-2014, 11:34 AM #7Administrator
- 7,498
02-11-2014, 09:12 PM #8
02-11-2014, 09:41 PM #9Xtreme Member
- Apr 2010
- Brian DeLuca
- 1997 Trans Am WS6
- Piscataway, NJ
- 1,297
Fonse did not build the motor but machined the block. I assembled the engine myself but it drank oil like crazy. I recently had it pulled apart and I basically had under bored/oval cylinders. The engine never missed a beat though which was strange. I had my engine rebuilt by Ellwein Racing Engines in MD. Great guy to deal with and he has built many boosted LT1s. His attention to detail and communication are excellent. Check out his website and go through the builds. Mine is #48. I'm running a blower at about 19lbs.
17 Corvette Z06 - 11.05 @ 125
17 GMC Sierra Denali Dmax
02-11-2014, 09:49 PM #10Long Live the Opti
Didn't know that. I was under the impression Fonse built your entire motor. My bad.
I'll caveat mine with this: Mine sat on a stand unbagged (hangs head in shame) for 3 years while I was compiling parts. Valve seals dried out for sure, and I compounded that by dumping return oil from the turbo in on the heads too. I was getting a noticeable puff of smoke on throttle close, and smoke hazing at idle. I relocated the turbo oil return to the back of the manifold (where the distributor would have been) and that helped out the idle hazing a TON. But I haven't been able to track oil consumption because there was a massive leak that I've later rectified while doing other things (combination of manifold and valve covers). I'll know a lot more in a few weeks after I get the valve seals swapped and the car back together.
